Volume issue on Android Auto - Google Maps
migna
Francesco
Italy
Mach-e rwd extended
Ciao
I just noticed that when I try to lower volume in GMaps when I'm using it through Android Auto, the volume is again up at the previous (standard) level at the next navigation alert.
So apparently there's no way to set a lower volume for the entire travel and this is quite annoying since I don't need a so high notification from Maps to turn right in 300m...
No issues at all with the volume of the car on other apps... meh?
Brutakus
Vancouver WA
Star White Mach-E Select AWD Comfort/Tech Package
Are you trying to change the volume WHILE Google Maps is speaking directions? You can only change the navigation voice volume while the voice is talking-otherwise it just changes music volume.
migna
Francesco
Italy
Mach-e rwd extended
Yep sure and indeed I'm able to lower the volume when the voice on maps is speaking..problem is that the volume goes back to the previous volume level right after... very strange, I know
krafty81
Terry
2021 MME AWD EX Premium, 2023 Lexus RX350h
I have not seen that...
