Window switch peeling?
rico_fafs
Eric
DC
21 Mach-E & 07 911 S
Realtor
Hi all, curious to see if anyone else is having this issue. My passenger front door window switch is peeling up. Exposing the raw plastic below. So strange. I only clean my interior with water and Dawn dish soap mixture. Very diluted.
It’s a 21 Mach E 4 only 9500 miles on it.
Ford Mustang Mach-E Window switch peeling? 31E443A1-7C96-4F62-944C-FF25A8F573E0
Looks like a defect in the vacuum metalizing process (probably contaminated). I would bring this up with my dealer. ??
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
Do yo have a little “Picker” in your Family?
rico_fafs
rico_fafs
Eric
DC
Realtor
Yea I’ll bring it up in my next visit to the dealership.
And good question, I don’t. I’m the only person who is in the car 99% of the time.
Mari76
Mari
Cali
Ford Mach-E FE, 2013 Ford Explorer Limited
Same thing happened to mine. Told dealer about it and they replaced them.
Chapschaps
Oneil
CT
Mach E select Fusion energi
I’m having the same problem too
Ford Mustang Mach-E Window switch peeling? imag
PaulP
Paul
La Malbaie, QC
2022 Mach-E Premium AWD ER - Grabber Blue
I'm also having the same problem.
Rt1AWD
CA
MME CARt1 AWD
ford .....:rolleyes:
Bookworm214
Kim
North Myrtle Beach, SC
Rapid Red Premium Mach-Ex
Retired Truck Driver
The paint peeled off my Cancel/Resume button. The dealer replaced it under warranty.
DR.J56
This issue was/is happening on Explorers also. Not just MME.
2021-MMEx-RT1
CA
2021 MMEx CA Route 1
Yes
At least you still have the 'trim'. after the first month or so, my plastic trip piece popped right off when I pulled up on it to close the window (Passenger side).
The dealer replaced the switch under warranty, with the wrong switch. So the next month when I had to go back for yet another issue, they replace it again with the proper switch.
/...sigh
Jonno21
Derby, UK
/...sigh
? To be very kind perhaps the part numbers were only one digit out?
2021-MMEx-RT1
CA
Yes
Could be, however, the person who installed it should have known as it (the first one) would stick when you used it (up or down) so there was never a 'tap' to close or a 'tug' to open feature.
When you gave it a quick tug, it would stick so the window would roll all the way up instead of the little bit you wanted. And vice~versa on the way down.
Larry Paul
Larry
MME-GTPE, Sunbeam Tiger w1970 Boss302, 2002Rav4EV
I have two switches on the drivers door that are also doing it. I got a small paper cut from it when I slid my finger across the switch
Ford Mustang Mach-E Window switch peeling? Drivers door passenger front window switch
(was not expecting it).
I am taking it to the dealer.
