Mach1E
- Sep 5, 2021
- Florida
- 69 Mach 1, 11 GT, 21 GTPE- sold, 24 Taycan 4S, 20 F type R
Oh the 1/2 hp was completely made up. Was just using the same 1/2 hp drag example when someone talked about drag on a bicycle earlier.Do you have a source for those numbers? Or did you make them up?
I think it's highly likely that you're creating way more drag with the windows down than electricity consumption from running the AC. Air gets sucked in, swirls around, flaps the rear belts (seriously Ford, did no one test this?), and then is forced out as new air detaches into the interior. You want attachment, and for that air to hang on as long as possible, when the windows are open you're creating a swirling vacuumy mess around the car, this is the opposite of aerodynamic efficiency.
Given that the car was designed with CdA as a priority, it's really hard to see this any other way.
That said, if you want to open your windows, by all means open the windows. I do it too, some days it's nice to drive around with them down and the rear belt flapping.
Real hp losses from a modern A/C system are around 5-10 hp (proven by multiple dynos as well as drag races).
And windows down drag? Is in that same 5-10 hp (proven by multiple fuel efficiency real world tests).
Bottom line? This has been tested many times. Lower speeds? Windows more efficient.
Higher speeds? A/C more efficient.
But the difference isn’t that big. And who drives with the windows down at 80 mph anyways? If you were hypermilering, you’d probably just have them barely cracked at that speed! And probably only the front windows.
With the Mach E though, if the compressor is always running, may be a little different.
