Wired thumping sound
rtrgjr
ric
des moines wa
2023 Mache Ca Route 1
I just brought my 2023 Mach-e California route 1 for 10K inspection which included tire rotation now there is a strange low level thumping noise that comes and goes It was never there before was wondering if anyone has run into this?
Could it be a tire be out of balance? I checked to Tire pressure its right on, everything looks normal as far as I can tell.
Are do I just need to put some miles on it to settle it down, all thoughts are welcome thank you
Tampamike
Tampa, FL
ā€˜24 Mach E Premium RWD
Yeah. Something like that happened to me at the dealer. After some service of which I don’t remember what it was, I heard a rattling noise as I drove away. Sounded like a nut or bolt rattling around. drove around the block and brought it right back. They found the culprit and removed it.
tbrumleve
Tom
Oregon, USA
Not normal. Nothing should need to beā€settle downā€ after a repair or service. Details will help folks help you. Is it while driving? All speeds? Can you tell what direction it’s coming from? Does it get faster / slower/ change pitch at all? Could be out of balance tire, could be something loose. You’ll need a visual inspection.
rtrgjr
ric
des moines wa
The thumping is while I am driving, at all speeds, my wife says it from the front passenger, no the thumping does not change in intensity or in speed or direction. sometimes it does not happen until we gone a few miles other time it starts right away. I will contact dealership and have them check it out will post if the find anything
NY_Cade69
Cade
Just curious, does it only happen when you're wired? :LOL:
rtrgjr
ric
des moines wa
that's the weirdest part no, stranger happen when I am wired though LOL :blush:
rtrgjr
ric
des moines wa
Ok went to dealership they did complete inspection and found nothing wrong with vehicle. then road tested and could not duplicate thumping. But the strange thing is now the thumping noise is gone. Maybe something was not put back right during the 10K service and when they went back in to inspect it got put back correctly so all end well, (y)
