Would this work?
Clicker
Jerry
Zephyrhills, Florida
Mustang Mach e
Going to visit old friends next week and want to add some miles before heading home that evening. He said I could probably plug in in the garage dryer outlet. He checked the circuit box and said the dryer has two 30 amp circuit breakers. Does that make the outlet a 60 amp outlet or is it still 30 amps? He's going to send me a picture of the outlet at least I would know if that would work. The breaker part I have no clue. Anyone know if this configuration is safe?
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
That's a 30A circuit.
Clicker
Clicker
Jerry
Mustang Mach e
Thanks, Sam's Club is 2 miles from their house so we will make a little side trip. They will probably want to ride in Scarlet anyway so we'll spend 30 mins in Sam's and drive home happy.
TheVirtualTim
Dearborn, MI
240v circuits look like two breakers that are grouped together. It is really just one circuit.
The mobile charger will want to pull 32 amps ... too much for the 30 amp circuit breaker. It would need to be a 40 amp breaker. A car should not pull more than 80% of the breaker's capacity ... so 24 amps on a 30 amp breaker.
If you had a 24 amp mobile charger (such devices do exist) then you'd be set. Ideally ... it would be great if Ford would do a software update that lets us set the max rate of charge in the car to allow for safely charging on lower amp circuits.
You'll need to buy an EVSE designed for dryer outlets (below). The provided charger isn't compatible.
https://www.amazon.com/Megear-Charger-Portable-Electric-Charging/dp/B0922R5MYH/
https://store.clippercreek.com/level-2-charging-station-16-amp-amazinge
These will only work with newer 4-prong dryer outlets (after 1996), older 3-prong outlets do not have a ground and therefore can't be used.
highland58
IT Solutions Architect
I got this on amazon, it says unavailable now.
ONETAK NEMA 14-30P to 14-50R 120V/240V 30 Amp 4 Prong Male Plug to 50 Amp 4 Prong Female Receptacle Generator Welder Welding Dryer PHEV EV Charger RV Power Cord Adapter Connector
It is a 14-50 female to 14-30 male adaptor. I have not tried it yet, but it should work. The EVSE that comes with the MME does fit into the female side of this. The reviews said that people have used this in a campground with the 30A receptacle, to charge their EV.
Ford Mustang Mach-E Would this work? 1627355388596
You can't use this with the standard charger because it will try to draw 32A and it will blow the breaker. You need a separate EVSE to tell the car to only charge 24A or less.
MY21 J1 Premium RWD SR
@Mach-Lee is correct. There's a reason these types of adapters will not ever be UL Listed or Intertek tested.
People using these successfully are likely charging older vehicles with smaller built-in chargers.
TJ-Mach-e
TJ
New Mexico
2016 Merc S550, 2021 MME AWD ER
I have been using mine with no issues since I got my Mach-e two weeks ago. It’s on a 30a breaker and has not tripped once. It’s adds about 17mph.
That's a little concerning. I don't know what it's actually doing, but if it's drawing more than about 28 amps the breaker should eventually trip. If you have a faulty circuit breaker that doesn't trip on spec you're going to be damaging the wires.
It's possible the charger sees a huge voltage drop from overloading the circuit and cuts back the current, but this is definitely not something you should rely on to make an improper practice safe.
This is a case of "just because it works doesn't mean it's okay". I can drive just fine with only two lug nuts on my wheel but that's not a good idea either, eventually something could go wrong.
