10.2.0 Update postponed
Fa_
Canada
MachE Premium eAWD ER
Hi there, got the update message on my 2024 AWD ER. Connected the car to the L1 charger with around 35% HVB charge and pressed update now. The update didn’t go thru stating “
Update Postponed
Your latest update was postponed because the vehicle battery was low.
The installation is scheduled to retry tomorrow at 1:00 AM.
Okay, so I left the car on L1 charger and this morning I got the same message. The HVB battery charge would be at around 42% at 1am when the update failed again.
Is it the LVB or HVB it’s complaining about ? If LVB isn’t it supposed to charge up from L1?
Ford Mustang Mach-E 10.2.0 Update postponed IMG_1492
thenew3
Central Coast CA
BMW X7, BMW X3, MME Premium 4X
This happened to me over the weekend. The LVB was at 71% SOC, while the HV was at 47%. I charged the L2 up to 61% and the update installed successfully. (LVB was showing 73% SOC when the update started successfully).
So I'm guessing the LVB has to be above 70% and HVB has to be above 60% for it to start.
When the update finished (took 17 minutes to install), the LVB showed 71% SOC while HV showed 62% SOC (yes HV went up).
Fa_
Canada
Thanks and how do you check the LVB SOC?
Ford_orr
orr
Los Angeles
Hellraiser
Or reach out to your Ford Adviser. I sat my Mach in the driveway on over the weekend for 9 hours and raised my SOC from 64 to 94%. Reached out to them before and after.
Reactions: Fa_
rugedraw
Javier
Miami, FL
Auto Sales
Take the car for a 20 minute drive and the leave the a/c fan speed on at least 5 during the drive. Try to install it manually as soon as you park instead of waiting for the auto-updates schedule to do it.
leehinde
Mach-E California Route 1
Update Postponed
There are lots of posts about this:
https://www.macheforum.com/site/threads/10-2-0-ita-update-fails.47338/post-985140
Reactions: Fa_
thenew3
Central Coast CA
For me, that doesn't do much. a 20 minute drive increase the LVB by 1-2% at most. Even with the fan blasting at full speed.
What works for me is to plug the car into a L1 or L2 charger (tune the L2 to lowest amps possible to stretch out the charge session). When I need to increase the SOC of the LVB, I plug it into my L2 charger, program it for 6 amps and let it sit for a few hours. It can go from 50% to 75% in about 6-8 hours.
Elektronik
Olegs
Latvia
Mach E RWD standard battery
so, did you manage to instal this update?
I have same now. Checked that even 73% of 12V battery is not enough for installation. Will try to push it up to 80%+
thenew3
Central Coast CA
What is your HV battery % at? Mine wouldn't start until HV was over 60% and 12V was over 70%
Fa_
Canada
I did, it just installed overnight again without me doing any tricks. The HVB was over 40 at the time of installation. The only thing I did was to unplug the usb charging device and dash camera which were not supposed to draw power while car is not on anyway.
Elektronik
Olegs
Latvia
HV Battery was 75%, so pretty high. Very strange that the update, which needs 20 minutes, can not be installed if 12V is 73%.
thenew3
Central Coast CA
I was able to manually start the update once my HVB was charged over 60%. the LV was at 73%. The update took 17 minutes and when it finished my LV was at 71%.
Elektronik
Olegs
Latvia
I charged LV to 75% and pushed to Update. It worked. Took 20 minutes and after the update LV was down to 67%. Seems like need to change LV.
