12V Battery access?
markboris
Sonora, CA
Hi Mark
where would the eyelets be attached. I though I had read that they shouldn’t be attached to the battery itself, is that correct
Thanks
As Rick said, positive to battery, negative to ground. For the Mach-E, the ground post that’s on the body next to the battery.
kennethjk
Ken
MME Prem. EB 4WD, X3, IX50
As Rick said, positive to battery, negative to ground. For the MME, the ground post that’s on the body next to the battery.
Right but since I am a simpleton on this stuff how do you get the eyelet attached to the negative post ?
markboris
Sonora, CA
You remove the ground post, slip the eyelet over the end of the stud on the bottom of the post and screw it back into the body. Now, I know the eyelet on the end of the connector is large enough to fit onto one of the several positive post connections on the LVB but not sure the eyelet is large enough for the body ground post.
I’m out of town until next week but when I return I can check to see if the eyelet on the CTEK connector will fit on the Mach-E negative post. If not you can always replace it with a larger one but I’ll check and get back to you next week. I have an extra connector to check it with. Maybe I’ll just install it in the car.
I’m out of town until next week but when I return I can check to see if the eyelet on the CTEK connector will fit on the MME negative post. If not you can always replace it with a larger one but I’ll check and get back to you next week. I have an extra connector to check it with. Maybe I’ll just install it in the car.
Further down the strut tower are more body grounds for various car systems. One of those can be used as well and they are smaller than the big grounding stud near the top of the strut tower. Just make sure you do not use the clamp mounted to the battery as your grounding point. ??
The 12V battery “jump points” are: Positive located near the fuse box (D, circled in red). Negative is a post on a tan that is mounted to the driver’s side strut tower (circled in green). You must remove two of the beauty panels to access them. Really dumb On Ford’s part. ??
I added this:
Some of us added a much simpler access point:
Ford Mustang Mach-E 12V Battery access? IMG_9018
There are a couple of threads with instructions on how to do this.
BTW, here's what Ford says to do for storage:
Ford Mustang Mach-E 12V Battery access? battery care when stored
kennethjk
Ken
I have the cutouts already and easy enough to just use clamps with the CTEK.
I hate having to remove beauty cover to get to battery and elsewhere , a royal pain and I know it doesn’t take that long but.
thanks for the advice
markboris
Sonora, CA
I also have the cutouts so I can attach clamps from the PL6100 battery power supply when updating the MME's software.
Ken, I'm getting back to you on the size of those eyelets on the CTEK 56-380 connector/battery indicator. They are large enough to fit over any of the battery's positive terminals and the main ground stud coming off the battery, going to the body. While I did not need to install this in my car, I figured since I had an extra one I would just in case I ever needed to charge my LVB without having to open the frunk or remove any panels. I also included the manual on the CTEK MXS 5.0 (1090) model I have in case you wanted to see the specs. The reason you don't see any of the LED's lit is they blink very quickly about every 2 seconds and none were lit at the time I took the shots.
Ford Mustang Mach-E 12V Battery access? IMG_6827
Ford Mustang Mach-E 12V Battery access? IMG_6832
Ford Mustang Mach-E 12V Battery access? IMG_6834
Ford Mustang Mach-E 12V Battery access? IMG_6835
Ford Mustang Mach-E 12V Battery access? IMG_6836
Ford Mustang Mach-E 12V Battery access? IMG_6837
su-ch+mache
carl
Germany
www.ford-suv-freunde.com
Escape MY17, Puma MY20, Mach E MY22 AWD ER TP2
retired buyer
I fitted the CTEK in a different way
Ford Mustang Mach-E 12V Battery access? 1691522090827
Cable is long enough to pull out the battery without any issues.
Connector has 3 LEDs to show condition reen, yellow and red
Ford Mustang Mach-E 12V Battery access? 1691522413692
JoeyD
Surprise, AZ
2018 Tacoma, 2024 MME GT
School Bus Driver
That connector device looks somewhat large. How much room is behind the area you mounted it in? Was it easy to route the wires up to the battery?
markboris
Sonora, CA
I didn't measure the depth of it but it's around 1 1/2" deep. There is nothing behind in that area where I mounted the connector as long as you cut the hole in that exact area. I would actually move it over to the left about 1/8" if I had to do it again because it is up against the bracket on the right side that the charging connector is mounted to. It fit perfectly fine though.
It was very easy to run the wires to the battery. You need to remove the wheel/tire and the rear part of the inner fender liner to gain access to that area. It is all open up under there. You can see right up into the frunk area.
Here's a photo without the connector installed.
Ford Mustang Mach-E 12V Battery access? IMG_6807
I really like this modification because it allows access to the LVB without raising the hood. If the LVB is dead, just pop open the door and connect up a charger. There might be other reasons you can't or don't want to open the hood as well. Cool.
Nice work, Mark. I am putting this on my car to-do list.
markboris
Sonora, CA
Thanks Mike. I've had that connector around for almost 3 years since I put one in my ICE Mustang which I use every few weeks. I figured better in the Mach-E than in the junk drawer. ?
iw2ntn
PierGiuseppe
ITALI - Milano
Ford Mustang Mach-e
hello,
i can't find the threads you mentioned for the battery caps. can you send me the link. thanks
markboris
Sonora, CA
JoeBeach
Central Florida
Mach E Premium 2WD ER, F150
I wish my Ford dealership offered that installation (CTEK by MarkBoris) as a service. I am not going to try it myself. :) There definitely needs to be an easy way of charging, trickle charging, maintaining the battery without opening the frunk and taking the car apart.
