12v Time to replace?
g8mb1t
Godalming, United Kingdom
24 MME Premium AWD ER, former keeper of 21 MME First Edition
With all the 12v failures,
did a test today, once the car went back into sleep mode(30min after opening the frunk).
Its a 2021 April build,
first test came back good, then the second test dropped below 75%, with the battery rated at 380CCA, can i recondition the battery, or should it be replaced?
Ford Mustang Mach-E 12v Time to replace? IMG_1593
Ford Mustang Mach-E 12v Time to replace? IMG_1591
Since you have a First Edition, I would say that the 12V battery has reached the end stage of its service life. Replace it since reconditioning will not do much for it. ??
jksu
LA
GT PE Shadow Black Night Pony
yup, replace
ipca204
if you have read about all the 12v failures occuring at the 3 year mark, why in the world would you NOT replace it for the $200 it costs??? c'mon....
Well, unless you are the gambling type, then I say since you are out of warranty, keep the original and see if you can set a record! :)
You could try a reconditioning charge which might help some, but at this point the battery is almost 4 years old.
All indications point to it being very close to replacement time. You could probably make it until spring if necessary.
Nikos
Taylors SC
17 Must GT, 21MME AWD, 22 F-150 Lightning
Aircraft Mechanic
I learned my lesson. After 36 months replace it. Almost every parts store has the battery available. Go with an AGM type battery.
Eagertrader
Norberto
Mustang Mach e GT
Realtor
Take it from me, the 12v battery died on me without warning and left me on the lurch 1 week before 3 years. It’s time to replace it!!
