Logal727
- C
- Aug 23, 2021
- Florida
- ā21 Carbonized Gray Mustang Mach-E Premium AWD Ext
There's a known issue with the Connectivity menu, it's server side so there's not much we can do about it on our end. All your connectivity features should still work though even if that menu isn't available. Mine is there sometimes and sometimes not, but everything works fine. There was a month or so I had to reset the TCU by pulling the fuse, but seems that's been fixed in one of the latest updates.I had the same exact issue in the past few days. Entering fault condition is that the connectivity pull down does not show up, and the charging stations do (and charging choice) are greyed out in the Ford navigation application. The modem icon does not appear at the top of the screen. The connected phone icon appears briefly at the top of the screen with a bar graph but the disappears. In spite of this, up-to-date Fordpass application running on current iPhone OS still retains the following functionality: remote start, remote lock and unlock still work, and charge state and charge condition info still show up while charging. I've never set up phone-as-a-key. So there is some connectivity active (which should mean the modem is good to go), but the menu pull-down does not load. Weird.
I tried the following fixes:
1 - Reboot the center panel using the volume up-next button on the steering wheel. No effect. Tried once at home while vehicle was connected to a known good WiFi network. Tried three times at dealership.
2 - Pulled fuse # 11 from the passenger footwell fuse box. No effect.
3 - "Key Cycle" - no effect. Note that I did this while sitting in the car, with the key fob and the blue-tooth connected iPhone. I did not expect this to work, as the same process had been essentially been conducted numerous times over the past few days as I used the car (essentially parked and walked away).
We also cycled WiFi on and off, and connected the the dealership's gets WiFi network. We also cycled the Hotspot on and off. I did not accurately capture where we did these in the sequence.
These were all done within a fifteen minute period sitting in the dealer parking lot with my sales rep. Started the car up after each of these attempts with no change. Then turned the car off and reviewed and discussed what we had done.
We surmised that there were things we did not know:
- how long is the boot cycle for the TCU?
- how long is the boot cycle for the modem?
- when we pulled the fuse, (which should have caused a hard reset), how long was the cold start of the TCU?
As we discussed this it was getting hot, 91 degrees and sunny outside the car, so i turned it back on for some AC. The modem icon appeared, and the and connectivity pull down was back. Problem fixed !
Not so fast.
The problem remained fixed all the way home, with three stops where i parked the car and walked away as i ran errands. The only anomaly I noticed was that the saved radios stations were gone, I think this was a function of pulling the fuse. Note to self - make a hard copy list of the stations and keep it in the car.
This morning I started the car in the garage with the key fob on me, but without the iPhone present. Back to square one, no modem icon, no connectivity pull down menu. Went and got the iPhone (which I know should not matter) and did it again, no change. It connected to the WiFi network, did not display the modem icon, and only briefly showed the phone icon, which I think I think is normal (but dumb, the phone icon/signal strength should be there all the time).
I would note that when I first tried it this morning, I believe the car was completely shut down. I say this because it did not wake up as i approached with the key fob (no parking/puddle lights). All dark until I pressed the button not he door.
I then plugged it in to charge and walked away. As I've been typing (at the other end of the house), I got the pre-conditioning notice that the car is up-to-temperature, and it is charging. So again, there is some connectivity.
Easiest way to see if your connectivity features/TCU are working is you'll see the Wifi Available symbol, and you can also pull up the weather info on the in-screen nav or see if the Live Traffic data populates. If all that works, then you're fine, it's just the glitch with the connectivity menu that for some reason is server side and they still haven't fixed.
