21P22 Charging Improvement Beyond 80% (Select Model)
jnthn98
2021 Mustang Mach-E
Edit:
The following data is for the Select model as it has a slower charging curve than the ER battery. I've seen data reported after 21P22 update, but that was for ER battery. In case anyone is looking for data points for Select, read on...
Original:
While getting my windshield recall done, my dealer applied the 21P22 Customer Satisfaction Program update on my Select MME. I knew it was going to improve the DC Fast Charging speed beyond 80%, but I didn't know by how much until now (thanks to EA's free charging on Earth Day).
Before update: 80% charging speed drops significantly to 9-10kW (basically level 2 speed)
After update: 80% charging speed is at 32kW (dropped from 49kW @ 79%)
Temperate was about 60F. I usually don't fast charge to a high SOC, but just to get more data, I let it charge to 91%.
At 90%, it was still charging at 32kW.
At 91%, it dropped to 26kW.
Other notes (not related to the update):
Since I have the Select model, the max charging speed is not 150kW. A long time ago, I read that it is 115kW max (if I remember correctly). I started charging at 38% SOC and I did briefly see charging at 114kW. It was very brief, but maybe it would have been longer if I started charging at a lower SOC.
Arjan
Arjan
NL
Ford Mustang Mach-E GT Performance
I noticed that the quick charging is dropping when you stay in the car, but it also depends on the environment and battery temperature. I got a little higher charge then you above 80%
It drops after 92% to undoable rates.
Ford Mustang Mach-E 21P22 Charging Improvement Beyond 80% (Select Model) snelladen boven 80%
Smaller battery charges slower. We get 44kw from 80 to 90%, then 34% to 95%. Didn't fast charge higher.
