235 vs 225 Winter Tires
Subliminal64
Burnsey
Ontario, Canada
2022 MME AWD ER (x2) "Darth Maul" & "R2-D2"
Working
For those seeking info on winter/snow tires and rims for Mach-E's, see the video below!
tuminatr
Saint Paul,MN
2021 MME GTPE
sales
Something to think about on this is if the tire you are going to has a different load rating you should adjust the inflation pressure. A higher load rating requires less PSI to support the same load. This is one of the biggest reasons to stay stock.
For Example the stock 225/55/19 103. 103 is the load rating at says at 39psi the tire will support 1800lbs
a 235/55/19 105 at 35psi will support 1830lbs @39psi it will be overinflated = faster center wear and less traction
here is a video that talks about it a little
https://www.tirereview.com/tire-inflation-pressure-placard/
Another way to think about it is a 235/55/19 105 XL should be inflated to 36 psi and doing this would hurt efficiency a little but also soften the ride of the vehicle.
