44A Charging Temperature Study
I had a request to look at my charging temps at 40-48A, so I decided to do that and share results of what is considered "normal" as a baseline for comparison. Some Mach-E are having problems L2 charging at 40+A due to software issues, hardware issues, EVSE issues, or some combination. I will be comparing values collected in the Car Scanner app and with FDRS (Ford's official scan tool software). Heads-up, there are some problems with the parameters in Car Scanner.
Temps are in Celsius because that's what us engineer types use. I'll convert some important values to F, but just be aware of unit differences if you are comparing with Car Scanner and you have it set to F instead of C.
I talk more about hardware at the end, but there are two main things that get hot while Level 2 charging, the charge port, and the on-board charger (SOBDM) which converts the AC to DC to charge the battery. There are three temp sensors in the charge port, one for the AC pins, and one for each DC pin. And there are four internal temp sensors inside the charger module. That's it.
Initial conditions:
Charging in a 28ÂșC (82ÂșF) garage after a drive. Level 2 charger set to 44A / 10.5 kW (can't do higher due to breaker limits).
Ford Mustang Mach-E 44A Charging Temperature Study IMG_2072
FDRS initial:
Ford Mustang Mach-E 44A Charging Temperature Study Charging temps before.PNG
I selected all the charging temps I could find in Car Scanner. In the process, I found that Car Scanner has some of the parameters labeled incorrectly. There are two ChgACT parameters (supposed to be AC charge port temp), the first one is actually the charger internal temperature (labeled wrong) and the second parameter is total nonsense (scaled wrong). It went from 72ÂșC to 176ÂșC during charging which is not possible. Those are not the real temps, so please ignore that one, I crossed it out. The ChgDCT parameter is also wrong, that is really a second internal charger temperature. The Car Scanner developer needs to fix some of these parameters so they display correctly.
FDRS tells the true story with the parameters. The charge port started about 22ÂșC (72ÂșF), and the internal charger temp started around 35ÂșC (95ÂșF) because the car was recently driven.
After 3 hours of charging at 44A (10.5 kW):
Ford Mustang Mach-E 44A Charging Temperature Study IMG_2073
FDRS 3 hour temps:
Ford Mustang Mach-E 44A Charging Temperature Study Charging temps warm 2.PNG
After 3 hours of 44A continuous, the AC pins in the charge port (BC_COUPL_TEMP_A) have warmed up to 55-59ÂșC (131-138ÂșF), or about 30ÂșC above ambient. This is reasonable. I'm using a new ChargePoint J1772 cable. The ChargePoint J1772 cables do get warmer than other brands at 40+ amps because they use smaller conductors (9 AWG). Based on the 9 AWG wire gauge and 44A current, the 50A rated contacts are performing as expected:
Ford Mustang Mach-E 44A Charging Temperature Study Connector temp ris
I don't know how hot the AC pins can get before charging slows down, but the J1772 spec says they need to handle +50ÂșC over ambient. Of note, Car Scanner does not actually have the parameter for AC charge port temp (remember it's labeled wrong). Only the DC pins, which aren't used for AC charging.
The DC pins (B+D) warmed up to about 36ÂșC just from the nearby heat generated by the AC pins. These temps are reported correctly in Car Scanner (ChgDCT1 and 3).
The four internal charger temps varied from 61-82ÂșC (142-180ÂșF). These cycle up and down with the fan (more on that later) but 82ÂșC/180ÂșF seems to be the upper limit where fans and pumps kick into high gear. The internal charger temps should not get higher than that, or charge rate may be dropped to protect the charger components from thermal damage.
Pump and Fan operation:
Let's talk about the thermal systems on the Mach-E and how they should work during charging. The on-board AC charger (located under the top frunk cover) will generate heat during the power conversion process from AC to DC. This process is about 90% efficient at 240V, so 10% of the power gets converted to heat, or about 1.1 kW of waste heat at 48A. The charger is liquid cooled, so this heat gets transferred into the motor/electronics coolant loop, and is ultimately dissipated through the other components in the loop, or through the radiator/fan. The on-board charger (SOBDM) is component #17 in the below figure:
Ford Mustang Mach-E 44A Charging Temperature Study imagen2
The order of components in the AWD motor/electronics coolant loop is as follows: Reservoir, pump, on-board charger, DC/DC converter, rear motor inverter, oil heat exchanger, front motor inverter, auxiliary pump, and radiator. This varies slightly, RWD doesn't have a front motor, and on GT models the plumbing is a little different.
When you plug in and start charging in summer temp conditions, you should hear the coolant pump start running (sounds like a quiet hum). This is going to circulate heat around the loop to the other components, warming them all up. This could take some time if they are cold to start, and in cooler ambient conditions the passive thermal radiation from the components may be enough to dissipate the 1kW of heat without using the fan. Essentially the motors can act as radiators, up to a point. However if the coolant or charger internals gets too warm, then the SOBDM can request the cooling pump speed increased or the radiator fan to run. This will bring down the temps in the loop, the fan shuts off, and the cycle continues with intermittent fan use. Those of you in really hot climates like Arizona will probably see the cooling fan run continuously during charging. Or if you plug in to charge right after a drive, the coolant in the loop might be hot already from the motors, so the fan could run right away.
Now let's observe operation and look at the temps in FDRS during a fan cycle, and after charging stops.
Right before the radiator fan turns on, everything is hot. Coolant pump is running at medium speed. These are peak temps:
Ford Mustang Mach-E 44A Charging Temperature Study Before fans on
When 82ÂșC is reached, SOBDM requests cooling fan LOW and pump move to HIGH:
Ford Mustang Mach-E 44A Charging Temperature Study Fan and pump on
Fan runs on LOW for about 20 minutes until internal temps decrease below 70ÂșC, fan no longer requested:
Ford Mustang Mach-E 44A Charging Temperature Study Fan off
As soon as charging finishes, temps drop rapidly, pump reverts to MEDIUM.
Ford Mustang Mach-E 44A Charging Temperature Study Pump down, charging finished
And finally 10 minutes after charging has stopped:
Ford Mustang Mach-E 44A Charging Temperature Study 10 min after sto
The last point I'd like to make is that the charge port is not actively cooled. You can see the temp in the upper left, it stays at 59ÂșC the whole time (thermal equilibrium) regardless of pump speed and fan running, these do nothing. It's completely passive heat dissipation. The only thing that decreases charge port temp is reducing the charging amperage. You can see it drops rapidly as soon as charging is stopped.
If either the charge port or the charger internals are overheating, you will see the charge rate decrease or stop until things cool down enough to resume.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Retired Engineer
Thank you Lee. What a comprehensive analysis. Hopefully the Car Scanner developers will update their tagging and resolve the issues you found. And I gotta say that 176 “temp reading” made me laugh - especially your annotation.
The last time I charged the car was in the garage and had not been recently driven. It charged at the proper speed (11 kW) the entire time. The previous charge the car was in the driveway, in the sun and had been recently driven. It was throttling the charge speed until I started the car in accessory mode. I wish I had some Car Scanner data to see what happened and why turning the car on stopped the problem. I can only guess the coolant was not circulating properly or the fan wasn't running fast enough (or at all) prior to me doing that.
Logal727
C
Initial conditions:
FDRS initial:
FDRS 3 hour temps:
I’ve noticed after one of the latest updates the fan will come on briefly and then turn off after I plug in in the garage, didn’t used to do this, I’d just get the coolant pump sound.
kronstein
Al
US
2025 Mach-E GT, 2022 Mach-E GT PE, 2021 Mach-E Premium 4X, 2020 Explorer ST
Recently I noticed it too, my car was in a desperate attempt to cool itself down and was running fan at max and was losing a charge, but when you turn accessory mode it would magically stop fans and continue to charge.
21st Century Pony
Martin
Arlington, Virginia
Very useful, incisive analysis... thanks Mach-Lee!
Information like this is useful for us Mach E owners and also for our eventual ownership and use of EVs in general.
I think turning on accessory mode briefly stops the charge, allowing the port to cool more than when it derates, based on what Lee has posted. That could explain what you saw also.
Had yours done the fan thing again? I’m wondering if the coolant pump gets stuck sometimes or something. Or just software glitch.
No, but that was an unusual charging session. I usually charge inside the garage, which is much cooler than outside when the doors are closed. When it happened, I was charging in the driveway in the direct sun. And it was in the 90s.
Snakebitten
Coastal Texas
2023.5 Mach-E
I'm late to the party.
But relieved to find this since Car Scanners default dashboard for AC charging freaked me out.
Ford Mustang Mach-E 44A Charging Temperature Study 1000022295
I previously had a Nissan Leaf that was tapped out at 28Amps charging rate. I still don't charge at the EVSE maximum rate, even though the recently acquired GTPE can take all the Emporium can supply.
Still, that AC Charger Coupler temp had me immediately hitting search in the forum! ?
Thanks gurus for letting me know it's a bogus parameter. By the way, regardless of whatever that PID is actually monitoring, it fluctuates quite a bit and will suddenly drop to "~175F" and then gradually increase again to WTH temps.
azerik
Chandler/Flagstaff, AZ
DevSecNetOps, General PITA
The Tesla wall connector would tell me it was 1700 degrees at the coupler.
Snakebitten
Coastal Texas
2023.5 Mach-E
So I double clicked the gauge and browsed the PID list.
Strangely, further down the list their was a second PID named "HV AC Charger Coupler Temperature"
It read what seems to be a reasonable temperature for what it might be?
Ford Mustang Mach-E 44A Charging Temperature Study 1000022296
azerik
I’ll go try this right now
Looks like it reads about 10f over ambient. My dash had that pid already (I might have messed around with it)
At the start it read 87,, my garage reads 77
Ford Mustang Mach-E 44A Charging Temperature Study IMG_6354
After a minute^^
Note the minute on the next screen shot and then when I stopped the charge it recovered quick
Ford Mustang Mach-E 44A Charging Temperature Study IMG_6356
Stopped but left plugged in
Ford Mustang Mach-E 44A Charging Temperature Study IMG_6358
Yes the second ChgACT is a charge port temp, but I haven't yet conclusively established if it's the AC or DC pin temp. There are three temp sensors, one AC, and one on each DC pin. Car Scanner is weird, for all I know they could all be derived from the same single parameter rather than the actual readings.
Snakebitten
Coastal Texas
2023.5 Mach-E
Yes sir.
I found 3 instances of the PID description identical.
At least the value for the 3rd instance appears reasonable for the temperature based on the vicinity?
Ford Mustang Mach-E 44A Charging Temperature Study 1000022297
3rd instance
Ford Mustang Mach-E 44A Charging Temperature Study 1000022298
