Orangeeater
New owner, slightly confused
Here is a link where they say
WHAT CHARGE LEVEL SHOULD I SET MY VEHICLE TO?
For most Ford electric vehicles, the recommended charge level is 90%. Avoid charging to 100% when you don’t need that range, though 100% charge is is recommended before beginning a longer trip.
In the 2022 owner's manual it states "
Use AC charging when possible and minimize the use of DC charging. It helps to preserve your high voltage battery's efficiency and lifespan.
We recommend ending DC charges at 80% state of charge."
and
"With Charge Scheduling you can improve the high voltage battery's longevity by delaying the start of charging and setting a maximum charging limit. It is recommended to set your preferred charging times to be at least 2-3 hours after your typical plug in time. This allows the battery to cool before charging begins. Additionally, setting the maximum charge level to 90% for everyday usage reduces strain on the battery."
So...if charging at home (which is AC I guess) is 90% preferred or the maximum recommended? Is there any advantage to lower thresholds? Any engineers, electricians, or scientists in the forum?
and
