Apple Maps EV Routing Not Showing Up
xvolce
STL
24 mach-e premium
Hi guys,
I just got a 24 Premium Mach-E. Loving it so far, but having a problem with EV routing showing up. This is my first post on this forum :)
Here is what happened:
  1. When I got the car, I was able to setup EV Routing just fine.
  2. I wasn't getting software updates in the car,, so I did a factory reset on the car.
  3. After the factory reset, I removed the car from Apple Maps since the battery percent was not updating at all.
  4. Since then, I haven't been been able to re-add it. I've done a factory reset on my car again / phone. I clicked on my profile in Apple Maps to see if "Vehicles" is there. And nothing seems to work.
If anyone has access to tools that can help, I can provide my VIN or I'm willing to try things that I might have overlooked.
Any help would be appreciated!
Thank you
txaggies07
Aaron
Texas
2021 MachE FE Rapid Red
I personally prefer to not have mine setup because it gets rid of the time remaining on the trip in the Apple Maps CarPlay window when EV routing is enabled. Sorry, can't help you solve your issue though.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
What happens when you try to add your car to your Apple Maps?
I’m assuming CarPlay is currently setup on your phone.
xvolce
STL
24 mach-e premium
Nothing happens because there is no option to add it under my profile in Apple Maps and I don’t get any kind of of pop up or anything to add it.
zooka
Belleville, IL
2024 Integra Type S 2014 FJ Cruiser 2024 4Runner
delete the Apple Maps on your phone and then reinstall it via the App Store...next time you use car play it will set it back up for you
xvolce
STL
24 mach-e premium
That doesn’t work. There is no vehicle in my profile and I have the app already.
markboris
Sonora, CA
Don't take this the wrong way but you are trying to add a vehicle while the phone is connected to the car, CarPlay is running and you have Maps open on CarPlay, correct?
zooka
Belleville, IL
did you try removing Apple Maps from the phone and re-adding from the App Store. I had the same issue and apple support gave me this fix which worked, once you connect back to CarPlay it should prompt you
xvolce
STL
24 mach-e premium
update: my car updated to 10.1.0 today and the feature started appearing again.
not really sure what’s going on, is this feature apart of 10.1.0? I guess a factory reset restores the software to an older version and doesn’t just delete user data?
iPodSocks
Dylan
Omaha, NE
2021 Mach-E GTPE, 2021 Mach-E Select
I'm having the same issue. Bought the car used, had to factory reset to add it to FordPass, and am unable to get Apple Maps to acknowledge the connection. I know how it's supposed to work because it works fine in my wife's Mach-E. I've tried deleting Apple Maps, rebooting Sync, rebooting my iPhone, deleting and re-adding my phone to SYNC, deleting the car from my CarPlay settings on the iPhone, etc.
I'm hoping it gets an update and starts working again like yours.
bdeweese
Bob
WA, USA
24 Mach-E Premium
I didn’t think a factory reset reverted the version back - like the OP, I thought it just reset all the user data. Does it really revert versions?
xvolce
STL
24 mach-e premium
That seemed to be the case for me. I got a bunch of updates over a course of week or so and eventually the feature was enabled again. Seems weird that ford does that.
iPodSocks
Dylan
Omaha, NE
I reset my car 7 days ago, and haven't received anything except the BC 1.3 update I got right before I factory reset it. Hoping they start to show up or else I'll start down the FDRS rabbit hole...
