Autel MaxiCharger (40A)
lucky13
GA
2022 Mustang Mach E Premium AWD ER
I have an electrician coming out in a week to install a NEMA 14-50 outlet as well as to set up whatever EVSE I go with.
I haven’t seen much discussion regarding the Autel MaxiCharger (40A) with the built-in holster.
It seems to have a pretty good price point ($430 range) when to compared to similar ChargePoints, JuiceBoxes, etc.
From seeing other posts, I do not think it has a North American safety listing (UL, CSA, ETL). ?‍♂?
lucky13
GA
Autel’s website seems to indicate that it is UL/CSA certified.
Ford Mustang Mach-E Autel MaxiCharger (40A) DA0E3DD5-1360-40EA-9444-4DB6633D8013
I guess that means I can’t believe everything I read on the internet. ??
mache_matt
Matt
Philadelphia
Nissan Maxima
if you search on the forums, you'll find some comments / threads about it ..
i had it installed a couple of weeks ago .. seems to be a well built unit and set up was easy ..
but i dont have a car to test it with yet :(
Richard L.
Richard
West Babylon NY
2021 Mach E First Edition Grabber Blue
If you haven’t done so already, check with your local electric utility. I got my JuiceBox 40 for $179 and a monthly rebate for time of use charging.
manicsubmersion
Kevin
New Mexico
2022 F150 hybrid Lariat, 2022 MachE AWD EX Premium
I have one, Qualified for a rebate from my local electric utility, (PNM) New Mexico. I am having it installed this week. no car yet either. I assume PNM would not have qualified it unless it met the required standards.
The Electric Duo
Patrick
Oceanside, CA
machevlog.com
I have a ChargePoint but I got to test out the Autel. I liked it a lot. Good indicator lights and the app is full of features. I like being able to limit AMPs via the app.
