Avoid Highways Navigation
2021-MMEx-RT1
CA
2021 MMEx CA Route 1
Yes
Hi all, so the Mrs is learning to drive and avoid highways to go places (for now) I don't see a setting under navigation or even talking to the MME to say
"Navigate to Point A, Avoid Highways"
So she can get used to the drive before going crazy on the Highways.
Thanks!
Peugfan
Minnesota
Thanks!
Avoid highways?? Did you just want dirt roads? ?. What I remember is options for fastest time and shortest distance. Maybe there was one other option, I would have to go back and look.
Use GoogleMaps.
JoeDimwit
Waterford
Grabber Blue First Edition
Electrician
The pictures came out with a lot of glare so you may not be able to see the buttons I’m point ing at very well, but…
step 1. Open navigation
step 2. Tap the wrench button in the lower left corner of the map.
Ford Mustang Mach-E Avoid Highways Navigation 8BAAE7ED-FC8C-4B49-9118-B6C5FB7B9EEF
step 3. Select settings from the lower right corner of the pop up box
Ford Mustang Mach-E Avoid Highways Navigation 0F394E8C-2882-47D1-8A17-1D8DF5918BC2
step 4. Scroll down until you see Avoidances.
Ford Mustang Mach-E Avoid Highways Navigation E5574E0A-52CF-4A27-B32E-C0BCDE08FC5D
step 5. Select things you want to
Ford Mustang Mach-E Avoid Highways Navigation AA181E86-E124-4BB3-AAB6-81A404BDD274
ebeponyan
Puget Sound
2021 Infinite Blue Mach-E Premium AWD ER
I don't have the settings in front of me, but in the navigation app, hit the setting icon and check in the Avoidances tab to see if you can turn highways off. You could also try the Eco Route rather than Fastest.
ebeponyan
Puget Sound
step 3. Scroll down until you see Avoidances.
step 4. Select things you want to avoid.
My post but better ?
2021-MMEx-RT1
2021-MMEx-RT1
CA
Yes
Perfect! Don't know why I couldn't find/see this part, but here it is!
Thank You!
