Battery % drop and range
Stoy333
Columbus
Mach e
Hi All,
2021 Awd select
I’ve been waiting a while to post this until I had enough data and time to post it. Starting in August 2025, my battery percentage drops shortly after turning on and driving. I’ve seen it drop anywhere from 2% to 6% after driving less than 3 miles. My max range is 188 per gom 78 degrees out and had not done much highway driving.
Below are some examples of what’s been going on. I thought someone on here might know what’s going on. I have been waiting to take my car in to go over everything at my 60k miles tune up.
8/25/25: charged overnight from about 15% to 60% turned car on this morning (8/25) and drove about .3 miles and went down to 57%. It’s 70 degrees. Drove another 2.5 miles or so and dropped to 55%. By the time I got to work, which is an 8 mile trip (stop and go up to 45 mph with no climate on) I was at 52% SOC. Left work later in the day and got home with 49% going the same route and same temperature as the morning ie about 70f. No preconditioning.
9/22/25: plugged in 16% last night. Pre conditioning is off. Charged to 86%. Turned car on and drove about .2 miles at about 25 mph. Looked down and my battery percentage was 83%. Over the next 10 seconds the percentage dropped to 82% then 81%. Stated at 81% until I drove about another 3 miles. Got to work at 79%.
I RESET MY DRIVE HISTORY AND CHARGED TO 100%
9/26/25: no precondition morning. 58% turned my car in. 56% after backing out of driveway. Got to work at 53%. Got home 49%. Turned car off then on and went up to 50%.
10/8/25: turned car on and was at 60% looked down 2 miles later and was at 57%. No pre condition. Got to work 55%…drove 7 miles on way home 36-45mph and trip mi/kWh said 3.5-3.9 during the whole trip. 64 degrees out used 4% ie home w 51%…turned car on next morning and 52%, got to work at 47%, used 70 degrees auto low for 3 miles of drive 35-50 mph.
10/10- morning 40 degree no pre condition. 42% gom 84. Got to wait to work 38% no ac or heat use gom 82 miles. Drove 8.4 miles, trip 4.4mi/kwh, 5% accessories 11% ext temp. 35-47 mph.
10/12-charged overnight, 63 degrees, drive 1.5 miles no ac and only used the radio and dropped 6% 82-76%.
10/30/25: 8.5 miles morning 5.2kw/mi 46 degree preconditioned no ac and used 3% but had dropped 2% after driving 3 miles.
11/7: Drove 11.6 miles with precondition no ac use 3.5 mi/kwh trip 69% to 62% 52 degrees outside used 6% total.
In summary, I lose battery percentage quickly after turning the car on and beginning my trip. I’m not an aggressive driver and might drive on a highway 1 of 10 trips.
The dealer had put on new tires that are “good” rating (which is another nightmare story…) and also installed wind strips.
What caused my range to drop so much and way does my battery run out faster than before? Less than 60k miles. My trip Mi/Kwh calculates a much different range than the actual battery percentage and gom say. For example, see 11/7. Drove 11 miles and used 6% no heater, preconditioned, battery 66% w 129 range, and mi/kwh was 3.5
sorry for the long post!
Stoy333
Columbus
Mach e
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Retired Engineer
Thanks. I tried this one time a while back. It seemed to have worked for about a week then went back to being broke. I’ve not come close to 200+ mile range since before the summer. I may need to try this again. it’s so hard to get the battery to exactly 5% when I need my car everyday lol.
It doesn't need to be exactly 5%. The idea is to get it low and then charge to full. But yeah, it can be a bit of a pain to do the whole sequence.
If you're not having any actual issues (e.g., getting stranded), then it might be best to just ignore any oddness. It shouldn't cause any problems.
FWIW, I had a Prius (non-plug-in version) that had some oddness with the gas gauge. The reasons for it are somewhat complicated, but the net was that the gas gauge wasn't 100% reliable. This was a design defect, not a repairable. I ended up using the trip meter as my gas gauge and just lived with it. But there was one time when I ran out of gas but the gauge had 3 or 10 bars! (The point of this story is that isn't not only EVs that can have issues with fuel level.)
The battery management system is estimating the charge level. It's only an estimate. I think the Select model uses a LFP battery, right? Then you can charge to 100% more often, let it get down to 10% or so and charge it back up to 100%. Do that regularly. It will improve the accuracy of the BMS charge level estimate.
Hi All,
2021 Awd select
So why are you not charging to the same % each night? Are you plugging it in very late or using a slow 120V charger? The battery percentages all over the place like that is going to mess with the BMS accuracy since there is no repeatability, especially if there is no "OFF" time when the battery can sit and measure voltage relaxation after charging finishes.
If the car is still charging right before you leave, you will experience a larger percentage SoC drop when you start driving because the BMS hasn't had a chance to read the open circuit voltages after charging is finished (which typically takes an hour or two post charge). Cell balancing may also be affected. Using a 120V charger also exacerbates this problem because the losses are high and the net charge rate is too slow for energy to be accurately measured.
To improve your situation, please charge to 90% each night with a Level 2 charger (32A or greater). Make sure charging finishes at least 3 hours before you drive the car. After doing that for a week or two, perform a full battery calibration.
You can also have your dealer check your high voltage battery health at your next service appointment. But I think the issue is mostly your charging habits (as well as temperature changes). The BMS is the most accurate when it gets large repeatable charge cycles, such as 50% to 90% consistently.
Billyk24
William
PA
Battery temperture? This plays a big role. You get home plug it in and charge to xx while the battery gets warmer until it hits xx when the charging shuts off. Car/battery cools overnight. When you get in the car it reads xx with the battery temperature at that point. Backing out of the driveway and onto the residential street feeds new input to the vehicle's brain including a colder battery temperature. Vehicle's brain then adjusts the guess o meter number.
67 Stang Convertible
Rich
Georgia, USA
Physician
Just get in and enjoy your drive. I've been rolling in my Mach E since July 2021 and stopped worrying about the GOM.....I leave that to my wife LOL!!! #neverbeenstranded
You have an LFP, charge to 100% nightly and enjoy the instant torque and the smooth buttery suspension!!! ((*Well, ok maybe, not the buttery smooth suspension)) LOL!!!
AZBill
He has a 2021, it is not LFP.
Stoy333
Columbus
Mach e
There’s a charger at my work. I usually will plug in at my house (level 2) whenever I need to precondition. I have it set to 70%. I used to keep my home charger at 90% but stopped since I usually charge to 90% at work.
I usually lose percentages faster when I start up and hadn’t charged overnight/at work.
Thanks for that. Starting tonight, I’ll charge to 90% for a week or two then recalibrate.
Stoy333
Columbus
Mach e
I started worrying about battery percentage when my battery % started dropping out of no where lol.
moritzes
Stewart
OH
'25 Mach-E | '25 F-150 PowerBoost
I'm the '80s I had an Audi Fox with a broken gas gauge and used the odometer for determining tank fills. Eventually the odometer broke, too, and then it was just guessing and white knuckles.
Good plan.
I do the same charging, but I plug in every night (always to at least 70% in the morning) and I also try to wait and hit 90% at work. I set departure times when it's cold, which helps warm and top off the battery a little bit as well. That reduces the % drop further.
Rex
Rex
Dorset
Mach-E Premium AWD 2024
I too have some anomalies.
I have had the charge fail by 1% to reach the target charge in FP.
Lose 1% backing out of my down hill drive.
Lose 3% in 300 yards at 20mph from my house
GOM predicts 250 miles
I seldom get less than 3.3 miles/kWh more often 3.7. Some values never appear!
I measure charge efficiency two different ways but often get readings where I get more energy in than comes out of my charger. Over many charges I get 95.1% & 96.7% which are sensible values.
Charge efficiency is at its lowest when charging to 100%
Overall from miles and kWh I get 3.2miles/kWh
I do a calculation which infers my battery capacity at 92.4kWh
My battery has been dealer checked and they say it is within spec.
I have sent all this to Ford and they say everything is tickety-boo, so being gullible, I don't worry about it any more. However I do still keep all my data!
The Ford support person said the GOM is deliberately pessimistic. (He didn't use the expression GOM :) )
