Battery life indicator
FrankL
New York
2021 Mach e
Have had the car for 6 weeks. I use a Chargepoint 50 amp level II charger at home. Everything works seamlessly except the dash display tells me I'm 100% charged but it never shows more than a range of the low 170's for miles. In cold weather, 100% is as low as low 150's mileage. Both numbers are well below the 210 figure that is supposed to be the range for a 100% charged battery. I checked my software status on the display and I have the most current version. Anyone having similar issues? AM I doing something wrong? Love the car but a 170 mile range is hard to manage
heisnuts
Darrel
Model 3 Performance
As you will see if you search for cold weather threads, as the outside temp drops so will your indicated range on the guess o meter. There is nothing you are doing wrong, nor is there any problem with your vehicle. Your numbers are well within range from what others are seeing and what is to be expected given the battery size and given outside conditions at this time.
TheSteelRider
United States
'21 Premium RWD
The title of this thread is "Battery life", but it seems like you really meant "Battery range".
sockmeister
Pennsylvania
2023 Mach-E GTPE
SW Engineer
Please search the forum for the numerous, numerous posts on this issue.
Start with this one:
https://www.macheforum.com/site/threads/53-standard-battery-only-85-miles.12166/post-297977
joes723
Joey
Black Diamond
'22 GTPE IBSM "LITHEUM"
When people join the forum, they should have to attest that they will not then immediately post about the GOM and cold weather range; atleast not without searching the hundreds and hundreds of posts. Basic common sense, batteries + cold = decreased range. :D
hybrid2bev
2026 Rally
Welcome
Recommended reading to get you started:
90% recommended daily charging limit:
https://www.macheforum.com/site/threads/charge-100-but-range-195.12363/post-303284
Real range of the car:
https://www.macheforum.com/site/thr...ulate-how-far-your-mach-e-can-really-go.6104/
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
The only thing your doing wrong is
1: expecting EPA milage while not driving in EPA style nor conditions.
2. believing that the number on the dash indicates something tethered to reality.
Welcome to the learning curve of being an EV driver. Hopefully you learned a lot before diving into a $50K+ investment.
Rt1AWD
CA
MME CARt1 AWD
Investment ? ?
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
