Battery range drop
nopose
Canada
Mach-e Select AWD
Charged my mach-e select AWD 2023 to 90% before driving 130km, stopped for roughly 10 minutes to pick stuff up. Battery was a little below 60% with an estimated remaining range of 190km. When I started the car and started driving, the battery dropped to 50% with 77km of range. Fortunately, I only only had 8 km to go to get back home. When I arrived at home, I was at 44%. Isn't this an insanely low battery range? The range suddenly dropping by more than 100km gave me quite the scare. Anybody experiencing something similar? Should I have it checked at the dealership?
It was a sunny day, about 15 ° C so I would not think the weather affected the battery much.
Ford Mustang Mach-E Battery range drop 20240529_182037
Question, when was the last time you charged it to 100%. With the LFP pack you need to do that with some frequency to maintain the battery calibration.
AngryMan
Living the good life
First try what Lee says .Hes our resident guru....BUT ....I had a similar yet opposite thing happen . Started car and it showed 75 miles of range . I knew this wasn't accurate but I couldn't spend a lot of time thinking about it so I pulled car outta garage . As garage door was closing it went up to 115 miles . As the door finally hit the ground the mileage/range finally reached its correct number. Happened once . Hasn't repeated ....and it's also a 23 but a GT. STRANGE
nopose
Canada
Mach-e Select AWD
How often should I charge it to 100%? I rarely do it.
But, I had it charged to 100% that same morning because I knew I had a longer than usual trip that day. It showed 418km which did not look right to me. It quickly fell down to a reasonable (as advertised) range while driving. I drove 135km to another city (reached there with 62% battery). Since I was spending the day there I charged it to 91% on a level 2 charger. It was plugged for 4 hours. After that I drove back home, which is the trip I described in my original post.
I should have had no problem driving back without charging. But with that sudden drop, I realize I probably would not have made it back home if I had not charged it back to 90% during the day. Which does not make sense since my trip was only 270 km total.
Is your battery LFP? If so, Ford says you CAN charge to 100% every day and you SHOULD charge to 100% at least once a month.
