Battery will not charge
wilkensc
NJ
Mustang Mach-e Premium AWD
I took delivery of my Mach-e Premium AWD on Saturday. When I plugged in at home, the battery would not charge. Dealer has the car since Tuesday and have not been able to charge. Ford engineers have been contacted, but still no solution. Anyone else have this issue?
You'll need to share more details.
Which charger are you using?
Which charger did the dealer use?
Have you tried other chargers, other outlets that were known to work?
What outlet(s) are you plugging into?
Is the connector/pigtail fully seated into the charger? Is it fully seated into the wall outlet?
What happens on the charge port lights or on the dash display when you plug in?
mountp
Bob
Hilton Head Island, SC
2021 GB ME FE
I had similar issue with the provide charger. The solution for me was to try the 110 volts then the 240 volt line. I believe I failed to push hard enough to get the cord fully seated for the 240 volt line.
wilkensc
NJ
Thanks
I used the charging cord provided with the vehicle and a 240v outlet at my home.
I also used a public charging station.
Not sure how the dealer tried to charge it.
Port lights are all normal - blue indicators
dash display normal
Ford Pass monitoring indicates "Charging", but capacity never increases, the only change is the time to fully charge indicator.
The dealer is instructed to charge the car prior to delivery. I would ask them if it took a charge back then.
Then I would check the charge settings. It might be set to charge during off peak hours.
Thanks
dash display normal
Did the charge percentage increase while FordPass says it is charging?
SteveJo
Chadds Ford, PA, USA
2010 Ford Fusion Hybrid, Job 1 Mach-e/X
I had the same difficulty and found it easier to use a rubber mallet to tap the connector down flush with the body of the EVSE. I'm not anxious to swapping it out...probably have to tie it between a pair of mule teams. ?‍♂
Omar
OMAR
Dayton
Ford Mach E
Military
Same thing happened to me. I plug in the 110 ac and I got the 3 lights on the mobile charger. After 30 min playing with the phone app and the settings in the car still couldn’t get it work. At the end the car became possessed the ac started on his own, the heat sit was on and was making some noise trying to open the passenger door by itself. I couldn’t turn it off and now the battery is dead can’t open the main doors. The other issue is to jump the vehicle you have to remove the plastic cover under the hood not and easy task that should be simple.
Claycreate
Ellen
MachE
How was the issue resolved? The same thing has happened to my new 2022. Picked it up Friday night and Saturday morning it was back in the shop. They can’t determine why it isn’t charging and have put a call into Ford. Nine months waiting for production,, purchased car and now waiting again??
Omar
OMAR
Dayton
Ford Mach E
Military
Looks like I had a bad charger that the dealership replace. No problems after that.
