Beosonic
AtomicInternet
SC
Focus RS, Mach E Premium
Yea, I getcha, but an 8 in the APIM didn't work for me or several others that tried with both B&O systems. I though at first it may only work on the 6 channel DSP and not the 10 channel we have with the 18 speaker system, but same results in both cases.
This is what I show here:
Another member tried changing -02-01 Xxxx to a few different values to see if changing vehicle types helped any, but that didn't help, either. Turning noise canceling on/off also didn't help. We're still tinkering with it. I plan on messing with it on Sunday when I have some time to try and figure it out.
Did you change your E60D to E61D for DSP? I'm wondering if your APIM change won't show up unless the DSP supports it.
rugedraw
Javier
Miami, FL
Auto Sales
Yea, I did. I get the Beosonic menu to pop up, but as the video shows, no changes I make stick. It always reverts the dot back to the center.
Mach e Aankh
NJ
Mach e Ex RWD BLK
Self
Hi I did on MME 21 both changes and it popped up in sound setting with dot working but every power cycle I have to go in sound to enable profile. Any solution for that.
rugedraw
Javier
Miami, FL
Auto Sales
No idea. This is all very new and still a WIP.
rugedraw
Javier
Miami, FL
Auto Sales
Snakebitten
Coastal Texas
2023.5 Mach-E
This is the kind of missed opportunity that Ford drives me nuts with.
Here's a chance to deliver a teeny tiny OTA (or FDRS) that simply edits hex values in EXISTING customer's Mach-E's, and they get a new feature in a vehicle that yesterday didn't have it. Obviously the necessary software was already installed on my car, but the feature wasn't yet enabled.
Took 2 minutes after carrying the laptop out to the car.
Played around with it on a few songs. Pretty cool! Double tap for the win.
Ford Mustang Mach-E Beosonic IMG_20240929_182304_(550_x_1000_pixel)
Thanks to all you fellas that fuss and figure out these things, and then share.
So you enabled the UI, but does moving it around actually change the sound? The DSP would also need to have the software for it in order for the sound to change.
Snakebitten
Coastal Texas
2023.5 Mach-E
Yes, it absolutely functions. The trick is to move the dot to the area you choose, then double tap the dot itself. The double tap immediately makes the adjustments aurally.
And yes, it requires the Forscan edit in the DSP module, as well.
Double tapping is just turning surround mode on and off (which will definitely change the sound, but that's existing functionality). Are you sure the sound is changing from ONLY moving the dot, not double tapping it?
Snakebitten
Coastal Texas
2023.5 Mach-E
It does not change the sound just sliding the dot around.
When I tap the dot and the sound changes, it changes very differently if the dot was on "relaxed" vs if the dot was on "energetic".
And if you hit the Neutral button, it definitely undoes the aural changes.
I'll go out to the car and spend more time confirming the details
Dysan911
2023 Mustang Mach E GT
Technical Software Analyst
Can the FDRS mongoose cable be used for forscan mods?
Snakebitten
Coastal Texas
2023.5 Mach-E
Oooops!
@Mach-Lee You are right about the double tap. That cycles Surround/Stereo.
But I was right that depending on where the dot is, you get very different tonal output. Regardless of the double tap. But that's because the Beosnic pad IS working as you move the dot around, but not until you lift your finger. Lol
I definitely confused myself.
So in summary, Beosnic is working if you reposition the dot and let your finger off.
The quickest way to test if it's working is to slide the dot all the way down to 6-o'clock and let go. It'll immediately sound like the vocals put their hand over their mouth. All the brightness will be gone.
And yes, the double tap is a quick convenient way to cycle back and forth with stereo/surround.
Smartphone recording, so not hifi. But definitely captures tonal changes on Beosnic pad
Beosnic video
Oooops!
The quickest way to test if it's working is to slide the dot all the way down to 6-o'clock and let go. It'll immediately sound like the vocals put their hand over there mouth. All the brightness will be gone.
Beosnic video
Thanks, video does convey it's working. And it would be ridiculously simple for Ford to send out an OTA that enables Beosonic.
Spacey
UK
Mustang Mach E
Rather have this than the Karaoke thing they're going to bring out.
