Brake Service Mode- Final Update
BillPitman
BillPitman
Pa.
Ford Escape, ‘21 J2 Mach e, 2024 Maverick Hybrid
Thank you for posting the instructions Bill. I have a 2021 Mach-E 4 Select with 16K miles on it. The brakes grab at slow speeds and make a rubbing noise when applying at real slow speeds.
I find it hard to believe your rotors are bad w/ 16,000 miles, no way! You need to put your car in 2-pedal & drive it for awhile!
I have some steering wheel shimmy, under certain conditions….. , but all my rotors are shiny clean. There are some anomalies with this drive system, in regards to brake feel.
I’m working on figuring this out……..time will tell……. Bill P
azerik
Chandler/Flagstaff, AZ
DevSecNetOps, General PITA
All my rotors etc are arriving this week, I might sweat it out in the garage sometime this week and this thread will help me drive mine again next week ?
BillPitman
BillPitman
Pa.
Just be sure to check & clear any DTCs related to brakes/ABS systems prior to using the “ brake service Mode”……….! Bill P
azerik
I’m going to do at least 1 test run before taking anything off the car.
BillPitman
BillPitman
Pa.
Erik, Space White?! , if so, same here……..
Keep us posted……. Bill P
azerik
Yep. Space white Job 1 awd. What could go wrong? ;)
azerik
I looked in Forscan today and had a pile of DTCs. Yippie. Looks like my IPMA is still freaking out at random as I didn't have DTC's 2 weeks ago. Looks like any time I get the front collision failure warning it's adding in all these others. I'll reset and do the brakes tomorrow (fingers crossed)
azerik
Welp, brakes are done. It was a little odd that the brake service mode seemed to kick in before I was done keying in it's triggers. (I used the 2023 service docs Bill posted, thank you Bill) Doing the brakes was pretty straight forward. My crazy brake bedding procedure was annoying through. Had to do 30 (yes thirty) stops from 30 to 5mph with 30 seconds cooldown between each cycle.
Turning brake service mode off triggered a "Brake System Fault" Which cleared after 2 key cycles (it was really a failed test because I guess it queried the module before it was actually booted coming out of service mode.) Time will tell if this helps.
BillPitman
BillPitman
Pa.
Welp, brakes are done. It was a little odd that the brake service mode seemed to kick in before I was don't keying in it's triggers. (I used the 2023 service docs Bill posted, thank you Bill) Doing the brakes was pretty straight forward. My crazy brake bedding procedure was annoying through. Had to do 30 (yes thirty) stops from 30 to 5mph with 30 seconds cooldown between each cycle.
Glad to hear that your service went fairly well….. Thank you for the follow up! Bill P
Please check out this video……. Bill P
Watch "It’s Vibrating When Braking & It’s Not the Rotors. How to Test!
