Brake grinding
Dan the Man
Chicago IL
Fusion Hybrid
Realtor
I have 16,000 miles on my car and I have always used one pedal we recently have had snow so I turned one pedal off and use the brakes. I noticed that When I am breaking right before the car stops there is a grinding noise coming from the front wheels.
Is this happening because I have have always used one pedal or do I have a break issue?
Thanks in advance for your replies
Scooby24
Olathe, KS
'25 BMW i4 M50; '25 MME GT
Healthcare IT
This is completely normal. Your rotors and pads are a bit rough due to lack of use. You can 100% bed them in and get them perfectly smooth and silent and then drive around with 1 pedal for a bit and they will be right back to noisy again in short order...all from lack of use.
There's no cause for concern.
edit: I should add...using 1 pedal or not, the blended braking functionality that leverages regenerative braking first even without using 1 pedal driving ensures you will pretty much always have this behavior unless you're always turning off traction control.
Dan the Man
Dan the Man
Chicago IL
Fusion Hybrid
Realtor
Thanks!
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
I’m a 100% 1P user. Every so often, every 6 months or so, I drive down the neighborhood at about 20-30 MPH and do a few panic brakes to get them cleaned up.
alexgorod
Alex
DBA
Alternatively, it is possible to switch to neutral and gently press the brake pedal to engage the brakes, there will be no regenerative braking in "N'. I do it sometimes after the car wash.
braking... brake...
waltcs
Canton, MI
2024 Mustang Mach E
And another forum, I recommended taking your vehicle out and letting her rip then slamming on the brakes. Repeat as necessary until the squeaks are gone.
