Brake Service?
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
I don’t know what salt does to brakes, but the brakes on the MME will likely last 100K miles, at least here in Seattle.
I had a Leaf with 90K miles and the pads still looked brand new.
I was LOL’ing at your grumpy response to my obvious sarcasm to someone coming up with a hack. I’m a new member looking for info. Thanks for being so welcoming.
Ah. It came off as LOL'ing that you knew better, because you can always hack a car and do it yourself.
So we both misinterpreted each other. ;)
canmachine
canmachine
Ottawa, Canada
2022 MachE Select AWD SR,
Pick the dealer with the most approachable EV Tech and Service Rep. They are out there... just not at all the dealerships. Bring them pizza ;)
I us
I usually bring doughnuts. I guess I’ll have to step up my game plan.
canmachine
canmachine
Ottawa, Canada
All good. That happens on the internets. I guess I’ll be bring it in every spring to the dealer to have them serviced.
canmachine
canmachine
Ottawa, Canada
The salt spray from the roads washes all the brake lube (especially the rear) off the sliding surfaces. Then they seize up (usually one side or the other) and you get uneven pad wear or it will warp the rotors. I read somewhere that drum brakes believe it or not would be well suited for EV’s since they need less braking efficiency than a regular vehicle and drum brakes would need less maintenance.
21st Century Pony
Martin
Arlington, Virginia
... I read somewhere that drum brakes believe it or not would be well suited for EV’s since they need less braking efficiency than a regular vehicle and drum brakes would need less maintenance.
Back in the day, a long time ago, fancier motorcycles like BMW had I believe four-shoe drum front brakes... it's a good technology which got overtaken by a better technology. However, it did work.
