Status
Not open for further replies.
Mr. Toejam
Spence
So. Cal.
Retired - Dir of MFG Eng
I was shipped my Ultimate rear and it looks great. It’s nice when a manufacturer listens to its customers, pivots, and then delivers a better product.
1) looks great. It also has a little light “leakage” on the back side along the edge of the adhesive. I’m not sure if this was intentional, but it really gives a nice halo around the pony.
Ford Mustang Mach-E BSKT Ultimate Project Technical review IMG_5328
2) Here it is in reverse mode.
Ford Mustang Mach-E BSKT Ultimate Project Technical review IMG_5329
3)And for the question some are asking. How does reverse white light affect the camera? The camera can see the pony hooves. Because of that, there is a little bit of light haze that the camera sees. As a note, I intentionally left my camera a little dirty as this produces more haze. And even then, the haze is minimal. I later cleaned the rear camera, but the video got messed up. But it did look a little better. I removed the black vinyl tape that I previously attached to my camera to block the light (when I get a chance, I will add back the black vinyl tape to the rear camera to see if this eliminates the haze 100%. But honestly, I don’t think it’s necessary. Here’s a short video showing the amount of haze created by the pony in reverse mode. In my opinion, it has no negative effect with the reverse camera with regards to clarity on what’s behind you.
Ford Mustang Mach-E BSKT Ultimate Project Technical review IMG_5334
So all in all, well done by BSKT.
@Mr. Toejam, for the white reverse light are you still tapping into the wires below or is it now plug and play?
You still have to tap into the reverse light down below. There are no reverse light wires in the liftgate at all.
Mr. Toejam
Spence
So. Cal.
Correct, but since Mr.Boris said it, I am just wasting keystrokes. But if you had a previous unit installed, it’s the same harness.
Brucelan
Bruce
China
bsktdesign.com
Mach e
Manufacturer
@Mustang-Vader, where are the heat dissipation openings on the ultimate pony? Is it in the front or back?
Would putting paint sealant, a ceramic coating, or even car wax affect the membrane's ability to dissipate heat? I use products with SiO2 when washing my car so I am wondering if I need to be mindful of how I wash the car once the ultimate is installed.
Also, in comparison to the OEM lit pony, is the ultimate pony as robust or even more robust than the OEM one against the elements? I know that the ultimate is backed by the lifetime warranty, but I am curious to know from a technical standpoint the differences between the two.
Hi
DeusEx
It comes with a lifetime warranty for the LEDs, but doesn’t cover discoloration of the emblem. We think it’ll last longer if you ceramic coat the pony, and the heat dissipation holes are located on the back.We plan to replace all emblems within just 5 years, which matches the average lifespan of LEDs.
Brucelan
Bruce
China
bsktdesign.com
Mach e
Manufacturer
Thanks Mr. Toejam
Brucelan
Bruce
China
bsktdesign.com
Mach e
Manufacturer
We Are Officially READY 🔥
First, thank you everyone for your patience.
The delay was completely out of our control. The Chinese New Year and war‑related airspace restrictions pushed back the UPS pickup. They have finally arrived in the US, and as a gesture of appreciation, everyone will receive a small compensation gift for waiting with us.
Now… let’s talk about the Light‑Up Ultimate Pony — because this moment is truly special.
This project took two years of trial, error, breakthroughs, and pure determination.
What Makes the Ultimate Pony Ultimate?
This is not a revision, not an update or a new version
This is a brand‑new Pony, engineered from the ground up:
•    Smooth, elegant startup animation
•    Diffused lighting
•    Advanced thermal control
•    One‑piece construction with ultrasonic welding
•    Built to last — truly
We’re so confident in this design that we’re offering a lifetime option.
Because the Ultimate isn’t just a product — it’s a commitment.
We invested heavily to create the best aftermarket light‑up Pony in the world.
So we turn to you, our valued customers:
•    Post
•    Review
•     Share
Now let’s make it shine.
Link to buy: Ultimate Pony – 2026 Light-Up Pony Mustang Mach-E Upgrade – Bskt Design
Ford Mustang Mach-E BSKT Ultimate Project Technical review 1775110355713-gf
Ford Mustang Mach-E BSKT Ultimate Project Technical review d045426c-0c23-4d38-9d6f-212d9909e641
Ford Mustang Mach-E BSKT Ultimate Project Technical review 660407640_1628427914967916_4384828902327380964_n
Ford Mustang Mach-E BSKT Ultimate Project Technical review 4fb64f05-e511-46d7-8a3a-4ee16607d6f4
Ford Mustang Mach-E BSKT Ultimate Project Technical review 42c8d3b7-425b-44fb-be10-a8c5c05c6ba
Ford Mustang Mach-E BSKT Ultimate Project Technical review 71b2b772-df82-459c-8758-80f97acffcf
Ford Mustang Mach-E BSKT Ultimate Project Technical review 233fbbd5-6f13-4d2a-9dc0-46c8ce61174d
Ford Mustang Mach-E BSKT Ultimate Project Technical review b335c88e-8ab3-4a01-a4ba-0052bab4c050
Ford Mustang Mach-E BSKT Ultimate Project Technical review eb2de53e-7b57-43e3-ac0c-507c4635c0b7
Ford Mustang Mach-E BSKT Ultimate Project Technical review fd208d27-35a7-4f5a-846b-c7f9cdd4be30
Ford Mustang Mach-E BSKT Ultimate Project Technical review 491964cf-0147-411b-9891-fdc9df95f6f5 (1)
Mustang-Vader
Mustang-Vader
Jannick
DENMARK
Ford Mustang Mach E AWD SR
Hi guys! Quick update — I had an surgery with my nose I’m getting out of the hospital on, and as soon as I’m feeling a bit better I’ll record the video for you.
If your Pony arrives in the meantime and you want to follow along with my install, just hang tight a couple of days — I’ll post everything right here.
-Jannick
Brucelan
Bruce
China
bsktdesign.com
Mach e
Manufacturer
-Jannick
Thank you Jannick. Fast recovery.
DeusEx
New York
2023.5 Mach-E Premium ER AWD
Please share how it looks with it on later. Looks good!
Brucelan
Bruce
China
bsktdesign.com
Mach e
Manufacturer
Just a reminder,
Scan your warranty card Qrcode
Follow the instructions carefully, and change the connector if you are already a client of Old Ponies versions
If you want the pony with DRLs and is not working the red with red wire, you must go to the passenger side with the long red wire and tap into this yellow wire (welcome wire)
Ford Mustang Mach-E BSKT Ultimate Project Technical review 3965334c-c4a6-4436-afd0-f04c54f11d2d
ysf39039
Yesai
Los Angeles, CA
2025 Mustang Mach E Premium Extended Range RWD
scientist
Hi all,
I installed my Ultimate pony. Looks so much better than the V3. However, there is an issue with my automatic headlights after installation. My headlights are set to automatic but it seems like the right headlights (passenger) are always on now. Has anyone had a similar issue and/or has a solution? Thank you!
Ford Mustang Mach-E BSKT Ultimate Project Technical review IMG_0803
Ford Mustang Mach-E BSKT Ultimate Project Technical review IMG_0802
Brucelan
Bruce
China
bsktdesign.com
Mach e
Manufacturer
Hi all,
Hi Yesai,
You need to disconnect one of the wires; you can’t have both connected. It’s either yellow or red, never both. I think this will solve your issue.
Thanks for sharing
ysf39039
Yesai
Los Angeles, CA
scientist
Hi Yesai,
Thanks for sharing
Thanks, Bruce! What’s the difference between the two wires?
Status
