Can I run two different widths on my front wheels?
nicholaspe
Nick
Utah
2021 Mach E
Those wheels and offset is fine now that I know you have a bit of poke and you like it. These won't be much different than you have now. Just make sure the center bore is 63.4. If it is not, you can use a centering ring but I don't like using them. Would prefer the wheel has the proper bore size to begin with. Yes, 8.5" wide wheel is perfect for 255's.
One more question: When I enter my vehicle information in the site (link above) it says it is not compatible with the Mach E. However I feel like they always say that when I’ve looked at wheels for my Mach E’s. Is this concerning?
THIS WILL NOT FIT YOUR 2021 - 2025 Ford Mustang Mach-E GT AWD Performance Edition * (2024)
  • Bolt Pattern: 5x4.25/108
markboris
Sonora, CA
They are wrong. It will fit your car and that is the correct bolt pattern (5x4.25).
