Can the navigation system show SOC for arrival?
T18C97
Rick
Dripping Springs TC
2024 Mach E, 2024 Cadillac Lyriq
Will be doing a road trip later this month and want to know is there a way to have the navigation system show what the state of charge will be at an arrival point? I’ve looked all over and if it’s there I can’t find it. Thanks
E90alex
Seattle, WA
‘25 MME GT
It should show the SOC at the next destination after you enter your destination in by default.
If there’s a charge stop in there then it can’t show the SOC at the final destination because it will depend how much you charge to at the charge stop.
T18C97
Rick
Dripping Springs TC
It should show the SOC at destination after you enter your route in by default. There is no option to turn it on or off.
Not seeing it. The small display will show how many miles to the destination and the current SOC. The nav app on the center display shows the route and estimated arrival time and current elevation.
You can edit the main map display in the map settings in that app on the sync screen. I’m no longer sure exactly what can be chosen as i haven’t look at that in years and generally use CarPlay anyway.
CarPlay will also show you projected arrival soc as well.
emichnov
Eric
Mass
2022 Mach-E Premium
I use Android Auto and Google maps (way better than the built-in nav), but, if I remember right, you have it hit "details" in the built-in nav to get arrival SOC.
Trueblue3605
,Phil
NC
2025 Mach - E AWD Premium
Android Auto has this feature
EasyPass
2021 MME Premium 4X, 2017 Fusion Energi PHEV
Android Auto with Google Maps definitely shows exactly what you are looking for. In fact, if you enter a destination without a required charging stop it will show the final projected SoC in negative percentage indicating the difference between the current SoC and the amount of new energy input that will get you to the destination.
Charge_Rob
Dearborn, MI
2024 Ford F-150 Lightning (2025 Mustang Mach-E Rally on the way!)
Charging Nerd
Yes, Connected Navigation has that feature - it can be viewed from the Trip Overview screen, or the Turn List. It also displays it prior to starting the trip. I use this all the time. Connected Navigation is the only tool I enjoy using for road trips where charging is required.
MacherAWD
North Shore MA
Healthcare Software
If you long press on Elevation or Arrival time you have a few choices, I thought that was one of them?
T18C97
Rick
Dripping Springs TC
I tried that and it’s not an option. It would be nice if it was always displayed and not have the go hunting for it.
Thanks for all the responses.
I solely use Apple Maps for my nav.
I do as well since my connected nav subscription expired last month. I’ll renew that subscription when Supercharger stations are easily available in connected nav.
