Can this be fixed? Fender & Door misaligned
Dysan911
2023 Mustang Mach E GT
Technical Software Analyst
Just noticed this recently. I did remove the plastic trim below the fender and saw the bolts were screwed in completely but beyond that, I am not sure how it can be fixed. Has anyone else dealt with something like this?
Ford Mustang Mach-E Can this be fixed?  Fender & Door misaligned IMG_7946
zvez
chris
ga
that's absolutely something the dealer should be able to fix, it's under warranty, Id take it to them.
Who jacked up your car wrong?
Dysan911
Dysan911
I thought the same thing but it was like this from day one. It wasn't until I was doing the first wash and detail that I noticed the passenger side was flush and the drivers side was definitely sticking out more. I was hoping it was something I could fix myself because setting up a service appointment is such a PITA but yeah unfortunately everything looked normal behind that black trim piece.
Monke
TX
Mustang
You will have to request the dealership sending your car to their body shop. Techs at the dealership may decide to fix it themselves and that may cause a nightmare situation.
Ford Motor Company
Official Ford Account
Hi Brian! I can look into your Mach-E's concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Mach-E's VIN?
If it was damaged in transport it’s too late for Ford to cover it. Damage must be reported within 48 hours of vehicle delivery. Your only hope is they consider it misbuilt somehow, but that seems slim. Might turn into an insurance claim if the dealer doesn’t want to pay.
johnnycombo
Pennsylvania
Most dealerships contract with someone to do dents and dings on their lot. That's a better way to go for a small repair than a body shop, so if all else fails ask for a ding and dent repairer price!
I've saved thousands with the ding and dent repair people.
maxior
max
Toronto
2023 Mache E
I know this old post …. But did you get it fixed I have exact same issue
thank you
Teslaeata
Nottingham, England, UK
Yeah, looks like impact damage with dent to rear of wing extending onto wheel arch trim, not warranty unless you can prove Ford or dealer caused it end even then it’s not exactly warranty as such but a liability arising from causation.
Should be fairly easily repairable. I’d see if paintless dent man could iron out dent in wing & improve alignment, depending on how OCD you are and if you’re going to pay for it which would eliminate paintwork - wheel arch trim could be repaired or replaced.
