Changed my wheels, will it affect my range
Jvilchiz
Joseph
Mustang Mach E
Detailer
I got wheels, do you guys think that will reduce my range!
Ford Mustang Mach-E Changed my wheels, will it affect my range 557B2AA6-CEA4-4F15-AD59-E8285F43447E
Nklem
Norm
Coast of Maine
Subaru Solterra
Mechanical Engineer
You went wider on the tires, 245 vs 225 you may see a slight range change. If you do, report back. The wheels may make such a slight difference I do not know if you will notice.
Scooby24
Olathe, KS
'25 BMW i4 M50; '25 MME GT
Healthcare IT
I'd bet if you did back to back straight runs on a flat surface on the same weather conditions you might see 10 miles loss.
In the real world, as mentioned above, I highly doubt you'd be able to tell any difference. Not enough to offset the benefits from where I'm sitting.
trutolife27
Bourbon Country.
Well, Any change is tire width, rim size or even the design can affect the aero. Each will be different.
Weather will also play a factor.
The common percent is 5% per wheel size increase or tire width, not factoring weather where it could be up to 10%.
So if you go larger size rim and width and less aero you could lose more.
pt19713
The aftermarket wheels won't be as aerodynamic as the stock ones. Add in additional rolling resistance from the wider tires, you'll probably see a 2-3% range reduction.
Mach-Tony
Anthony
2021 Carbonized Grey Premium AWD
Mechanical Engineer
Those look great! You will lose range. Depending on how you drive (freeway/streets) it will differ. I went with 245's on about 6lb lighter rim than stock and lose about 10% on the freeway but I don't see much difference on street/city driving.
Probably best to look into this stuff before actually purchasing new wheels but most of us don't mind losing the range for a better look.
You might see a very small increase in low-speed range. You will likely see a small decrease in moderate to high speed range. Since I am not privy to aero numbers for that specific wheel/tire/vehicle combination, any numbers would be guesses.
