Charge Rate
DBPE
CA
2021 Mustang Mach-E GT
Does anyone have seen a higher than 4kWh charging rate with Ford Mobile Charger Level 2, 240v, 32Amp for Mach E GT?
RosemarieS.
Frisky Filly
Georgetown, Texas
2023 Mustang Mach E GT
How do you calculate your charging rate? I have exactly the same car & charging equipment as you do. I was told that you multiply the amps times the volts to get the watts (minus 10% loss). So it is just assumed that the car is pulling in 7 kw per hour. I have no readout to confirm this. FordPass shows the duration of the charge, the miles added and the percentage added. I would like to know exactly what my home usage is for charging the car.
DBPE
CA
7.68kW is the rated output power of the Ford Mobile Charger, level 2. However the charging rate of which the Mach-E GT received mostly at 3-4kW, rarely at 5kW.
The latest updates in the FordPass app has the Charge Rate. It also can be calculated by using the Energy added / Charge Time in Hrs. = kWh in average.
In theory, it should charge at 7kWh at the beginning then slowly tapper down to 3kW after 60-65%. The highest charge rate I have seen is at 5kW but very selfdom, typically at 4kW then down to 3kW.
The Ford Connected Charge Station is an option for the Mach E which Ford recommended. This charger has an output of Max 48A / 11.5kW. I want to upgrade the charge to this but unsure of how much AC energy the Mach-E GT can accept.
With DC fast charge, it can take as high as 150-163kW.
Ford Mustang Mach-E Charge Rate Screenshot Charging_FordPass
hawkeye3point1
NH
Your outlet voltage has to be seriously low for this to be the case or the EVSE is faulty. I would check the CB and outlet for excessive resistance which results in heat.
On a 60-amp hardwired install, the MME can charge at 11.5 kWh, with an EVSE that can deliver 48 amps at 240 Vac.
You have outlet, wiring, or charger issues slowing your charge rate down. It should always show 6 kW or higher in FordPass. If the amber light turns on, Mobile Charger is bad and should be replaced.
Mach-E will accept up to 48A/11.5 kW.
NC-GT
Kevin
NC
2023 GT Performance
For OP- regarding the time value…
the pics you posted look to be before your charge session was complete. I had a similar reaction this morning when looking at mine. However you will notice that in the snapshot it shows “time on charger” - this number only indicates how long the cable was connected. (Not sure why they even report that)
To see actual Total Charge Time for the completed session:
Select Charging/ Charge Logs/ then select your session from list. Now FordPass shows you the Total Charge Time that you could use.
