- Jonathan
- Nov 25, 2019
- MY21 J1 Premium RWD SR
In case you were dying to know...
Thanks.In case you were dying to know...
Same here.What I am dying to get my hands on is the owners manual so I can dive into the features and settings.
Plugging in isn't an option where I work. I'm hoping the car will manage its own battery system cooling while parked and unplugged. I don't want to have to worry about that.Charge now at the office except for when it is over 110 ambient. In those conditions I plug in to allow the chiller to keep the battery pack cool but don't charge.
That would be a great feature for sure.Same here.
Walking by the Teslas at work at this time of year, I often hear the coolant pump running to help manage battery/electronics longevity. Ford should be doing the same on the Mach-E. (We'll soon enough find out.)
I just learned a few days ago that Teslas also have an option called Cabin Overheat Protection which runs for up to 12 hours after parking. It can be off, set to fan only, or set to fan + A/C if you want to keep the cabin at or below 105F. This explains why the Model X that I walk by at work is nearly always making a lot of loud fan noise while the other Teslas are significantly quieter. I wonder how much energy is being used, and if it even matters -- the interior should be built to handle the 200 degrees or whatever it gets to here in the hottest climates.
My friends model 3 loses about 7 to 10% battery while its out in the open at work with overheat protection on. He also uses sentry mode which drains some too.I just learned a few days ago that Teslas also have an option called Cabin Overheat Protection which runs for up to 12 hours after parking. It can be off, set to fan only, or set to fan + A/C if you want to keep the cabin at or below 105F. This explains why the Model X that I walk by at work is nearly always making a lot of loud fan noise while the other Teslas are significantly quieter. I wonder how much energy is being used, and if it even matters -- the interior should be built to handle the 200 degrees or whatever it gets to here in the hottest climates.
