Controlling Speed on Curves
Tetburyman
Washington
2024 Mustang Mach E Vapor Blue
Just back from first long trip in the MME and I have a question. I used Bluecruise extensively on the trip. There are many curves climbing through mountains between CA and OR, all carefully banked, wide curves that require little, if any, slowdown in most driving conditions. When BC (or ACC) is on the car slows 10 - 15 MPH through each curve. The slowing forced drivers behind to pass me followed by me passing them as the speed returned to the set speed. I ended up driving manually through the mountains to avoid the constant leapfrog. I like BC (my first time using) but regard this as a major flaw.
Question: Is there any way to control how much the vehicle slows for curves using either BC or ACC?
tbrumleve
Tom
Oregon, USA
You can turn it off, but you can’t adjust it for curves, only speed limit signs. Look for “Predictive Speed Assist” in your driver assistance settings.
Tetburyman
Washington
That is what I thought, but had to ask. Thank you
Tampamike
Tampa, FL
‘24 Mach E Premium RWD
You can just override it with your foot on the pedal without having to disconnect it. I’ve found that works pretty good until it’s just curve after curve like going up or down a mountain. Then I just cancel it and then resume when I’m in the flats.
AndyS_OSU
Texas
2017 Chevrolet BoltEV
Educator
I’ve had the same issue but sometimes when there isn’t even gnats curve. I don’t like the “just turn it off” suggestion. These are technologies meant to be used. I’ve also tried to override with the accelerator and the car literally fights me.
BlueCruise also tried to kill me and my family on a perfectly straight stretch of highway but Ford “can’t replicate the issue” so they have offered no fix. Meanwhile my family now refuses to ride in the car unless I turn off any driver assistance.
Never had the vehicle fight adding accelerator pressure.
Tampamike
Tampa, FL
“ Tried to kill you”?!
What happened?
AndyS_OSU
Texas
Educator
What happened?
On a straight stretch of interstate, the car acted like it was avoiding a hazard where none existed by swerving into a neighboring lane. There was another car present in that lane. The only thing that stopped us from running into them at 65mph was that my hand was on the wheel.
Predictive speed assist sucks. Yes, it slows down way too much. It thinks you’re a semi.
kbaybob
Robert
2022 Mach E
In my opinion blue cruise is worthless and can be dangerous. I have had it turn off without warning when the car was in a curve pointed toward a wall next to the road.
