josephyancey
- Joseph
- Apr 25, 2022
- Arkansas
- 2021 Mach E CR1 (Job 1)
- Software Engineer
I'm looking for some advice here.
I live in a suburban area but we do tend to lose power every few months for 4-12 hours from storm damage. So far we just tough it out but my home does have a critical loads transfer switch. I've tested it and the default load with all of this on is around 300W but could peak up to around 1000W if both refrigerators start at the same time and the blower for the furnace is on.
Since I've got a giant battery sitting in my garage, I thought that I might just get a 12V 2000W inverter and attach it to the car. It looks like the MME's 12V converter can do 160A and all I would have to do is leave the car "on" to keep that running. 5-10 days worth of critical loads backup power sounds pretty good. I've tested this out on my MME with a friend's inverter and a pair of jumper cables. Other than the cheap jumper cables getting very hot it worked fine for a 30 minute test.
Pricing out doing this right with permanently mounted 2awg wires to anderson plugs with a Renogy 2kw inverter comes out to a bit under $400. Now I'm thinking that if I'm spending $400 why not just get a decent 2000W gas powered inverter generator. Yamaha clones can be had for around that price.
MME As Inverter Pros:
MME As Inverter Cons:
Gas Generator Pros:
- No noise
- much smaller / more portable than a generator (for camping or whatever)
- no refilling it with expensive gas
- Can't drive the car when the house needs power
- possible risk in damaging the 12V converter
Gas Generator Pros:
- No risk to car
- Can drive the car
- much more "common" use case
- can more easily sell it if I wanted
- would likely feel more comfortable going to bed with it running (outside)
- Noisy
- have to buy gas(or propane)
- quality of the electricity (although I'm looking at units with very low THD)
- I've got to maintain a rarely used small gas engine
