Hammered
- Oct 4, 2022
- SE US
- 2022 PB F150, MME GTPE
No, unfortunately not. There's signals sent on the bus independent of forscan changes. When in reverse for instance the reverse lights need to activate, the rear BLISS needs to function including CTA, as well as the cameras. I couldn't imagine being able to change such a thing w/out impacting other systems that you want to be present. Eliminating the backup beeper alone is much preferred.You can't just make the FORScan change and have it disabled? Seems lame that that isn't enough to just trick the car into thinking it isn't there anymore. Bummer.
One benefit of the forscan change is that you can install a power switch for it and enable / disable it w/ out throwing a code. It does throw a silent code when viewed in FDRS as the module is missing, but that's it. No MIL or other issues present.
