HughJazzol
Thanks AliAt the curve it is a bit harder. Clean it up and give it a shot. You can’t make it any worse.
Just apply in small increments.
Clean it up? Remove small bits, you mean? To leave as perfect of a circle as possible?
Why in small increments versus just covering the area with one application? Does applying 1mm at a time build up with layers, so to speak, and that will look more even?
Instead of coating what's there now once which will color match BUT won't be even?
