DIY solution to repair a ding?
HughJazzol
Norman
Miami
2024 MachE Premium RWD
Project Manager & Swim coach
At the curve it is a bit harder. Clean it up and give it a shot. You can’t make it any worse.
Just apply in small increments.
Thanks Ali
Clean it up? Remove small bits, you mean? To leave as perfect of a circle as possible?
Why in small increments versus just covering the area with one application? Does applying 1mm at a time build up with layers, so to speak, and that will look more even?
Instead of coating what's there now once which will color match BUT won't be even?
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
Thanks Ali
Yes, get rid of all loose paint and clean with rubbing alcohol.
It looks like it’s a vertical surface, if you go too thick, it will run.
@HughJazzol, wait 15-20 minutes between each application.
