eponey
So this was helpful. I'm always plugged in so when I walk up to the car contactors will click and it'll flash blue, in a few seconds it'll turn solid blue but the contactors will stay closed....eventually the contactors will click open and it'll be white but I have not stuck around to see how long that takes.When you press the latch does the change port ring go fromblue to white?EDIT: Should go from pulsing blue to solid blue when you press the latch, and then white after you unplug. If it's solid blue, then charging has stopped.
