- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- Solar Sales/install
The inverter is just a 3000w pure-sine, around $300. Charge controller is a renogy 40a, and there is a 365watt module on the roof.Slick, what equipment are you using? I can make out the inverter but not the batteries in your photos.
The batteries are some ten yr old 12v-200ah deep cycle AGMs I pulled from a client's that was upgrading to Lithium. If you are considering something similar, I would suggest any 12v-100ah AGMs for the garage as a good balance between no maintenance, ok with temp swings down to freezing, etc. The 100ah are about the size of a regular car battery and much easier to move around.
If you put 4x 12v-100ah batteries in parallel you'd have enough energy for short outages.... and then you can back up with the MME, so you really don't need to oversize the stationary pack.
I keep them charged up with one (365watt) module on the roof for daily charge and light use in the garage to charge cordless tools, a little compressor, a little composter, garage radio, etc.
