Fender trim: Painted or Wrapped
LS61303
LeeSonn
South Bend IN
2021 Ford Mustang Mach E 4EXT Premium, Yamaha FZ07
IT Consultant
For those of you who have had the black fender trim above the wheel wells painted body color (like on the GTs), did you go with actual body color paint, or did you have someone wrap them? And why did you come to the decision you did?
I have seen a few people post about doing that, and all of them who did it had them pained, not wrapped. I have not seen any posts about wrapping the fenders, and I have spent a lot of time here over the past year.
@markboris painted the fenders on his Premium, I believe, so maybe he can explain why he didn't consider wrapping them. Probably because he wanted it to match his paint color exactly, which I don't think you can do with a wrap.
Stang68
Eruption Green Mustang Mach-E GT
I painted instead of wrapping for a few reasons, main one being color match. Space White is a tough color.
And who knows how well a wrap would stand up to wear and tear around the wheel well. I know plenty of people wrap their cars with vinyl but without a PPF on top of it it’s open to tears.
Ford Mustang Mach-E Fender trim: Painted or Wrapped 4E511154-BAE7-4B2E-BDAB-5510F31F7BE0
markboris
Sonora, CA
Mike (mkhuffman) is correct. I had them painted because I wanted them to match as perfectly as possible. While I didn't investigate colors for wrapping, I highly doubt I would've found one that matched Infinite Blue. #16
Ford Mustang Mach-E Fender trim: Painted or Wrapped IMG_6143D
CaPhil
Phil
Los Angeles
2021 Mustang Mach e Premium SR, Star White
Retired engineer
Do the fender trim pieces just pop off? I have a scratch on one of mine and want to replace it. Any idea on how much they cost?
markboris
Sonora, CA
Click on the link in my post that is above yours.
NoVAguy
None
Ford Mustang Mach-E Fender trim: Painted or Wrapped Attach0_20211011_192613
Painted for the same reason as everyone else.
A note about the clips holding the fender flares, many of the shops I got quotes from did warn me that there'd be a high likelihood a few clips may snap when taking it off. This is actually apparently by design as many OEMs make them as single use clips only (probably so people need to buy more).
Good thing is it's not difficult to get new clips, and while many told me it's highly likely a few might snap, I was fortunate enough to find a shop that was able to remove it without any clips snapping.. so I know it's possible to remove them without issue!
CaPhil
Phil
Los Angeles
Retired engineer
Thanks. Is there a part number for the finished trim in OEM gloss black or do you have to buy a primed trim piece and have it painted? I didn't see one on the Tasca site. I need a right rear trim piece.
markboris
Sonora, CA
Yes, all four fenders trims are available in gloss black. I don't have the part numbers for those but if you were to go to your local Ford parts department and give them your VIN, they can look up the proper part.
LS61303
LS61303
LeeSonn
South Bend IN
IT Consultant
Thank for the input folks! I figured painting was gonna be the route I was going to go, but was curious about wrapping. All the extra info and tips are appreciated! Now to find a local shop and get some quotes, come spring time. @NoVAguy Your build is so sharp, I am going to be doing just about every one of those mods to my Star White Premium! Gonna de-badge, tint the windows, and find a “grille” wrap. Ordered a new set of wheels and tires for the summer yesterday as well, so we will have similar builds! Thanks for being an inspiration lol.
@markboris That Iconic Silver GT is a sight to behold….. really like the spec and the wheels you put on it. Big fan!
markboris
Sonora, CA
Thanks for the complement LeeSonn. Thing is, Iv'e only posted a few photos of my IS GT since I am not quite done with it. With the holidays, haven't had the time to finish some last details.
NoVAguy
None
Appreciate it and glad I could be of inspiration!! Good luck with finding your local shops for the mods ?
Joey
Joey
New York
2021 Mach E Select
Was actually thinking about Hyper dipping all wheel trim, bottom door, rear bumper and front plastics...
Milthonvb
Milthon
Mach e Select 2024
IT Project Manager
Hey guys, Can someone help me with this? I need to buy a cover for this part of my 2024 Mach-E Select. It got hit and disappeared, but I don’t know how to replace just this piece. I was thinking about putting a cover on it — either carbon fiber or glossy black. Does anyone know if I can buy it somewhere online?
Ford Mustang Mach-E Fender trim: Painted or Wrapped tempImageyP0K25
