Fordpass 4.11 basically useless…
devildog125
'21 Mach-E AWD, '22 Hyundai Tucson SEL AWD
Law Enforcement Software Engineer
Since the update to v4.11, Fordpass is useless. Doesn’t show correct charging times, departures times, no alerts, incorrect notifications etc. PAAK still works but I’m thinking of removing it until a newer update comes out as I now get no use out of the app at all.
Nklem
Norm
Coast of Maine
Subaru Solterra
Mechanical Engineer
Yes, 100% true. I hope they update soon. They must be getting tons of complaints.
devildog125
I hope they fix it soon, as it really annoys me that they broke a bunch of things for a UI update.
DR.J56
Texas
I’ve been trying to change my departure times and charge % for the last week since the update and nada. I just get the roundy round arrow and then FP isn’t responding.
devildog125
I basically removed PAAK and am only going to depend on the FordPass to check to see if the car is "waiting to charge" for the time being.
HOFMACHFE
Adam
Hanover, ON
Chevy Bolt 2017, Mustang Mach E FE Grabber Blue
Yes, I have the same problems. Can no longer change my charging schedule and the charging logs no longer work. Please FORD fix soon!
I have the auto update button unchecked, yet it updated. Didn't think that was possible.
lbj
Lisa
Silicon Valley, CA
2021 Mach-E Premium AWD ER Infinite Blue Metallic
Retired Engineer
My experience is that the %charge doesn't show correctly in the app, so I tried changing it by 5%. Got the spinning circle and gave up. But, when I charged the next time the 5% change had taken effect. Didn't show the change in the app, but the car charged to what I changed it to. When I went into the settings on Sync, it showed the change. Annoying for sure.
OON7
Evan
New: 24 GT w/ perf. upgrade Vapor Blue // Old: 22 GTPE DMG // 21 Select CG
Mine just started working a couple of hours ago. It cleared all of my saved chargers, preferred times, save departure times. Got home and was able to set home charger back up. No more stuck on loading screen, first time since the update came out
Snowrider69
Ryan
Mach E First Edition
I replaced my Galaxy Note 10 with a Galaxy S 22 and the app is working great for me. I just setup PAAK and that worked flawless.
The instructions on both Sync and FP have dramatically improved from when I set up my old phone a year ago.
I can also say that the Note 10 worked 90% of the time. The biggest issue was that it didn't detect a key periodically, which was easily fixed by placing the phone on the charge pad.
