And remember, if youāre not part of the solution, youāre part of the precipitate. (Thank you Mr. McNally, my high school chem teacher!)There are no solutions in this thread. Only problems. ??
Still on 4.10 also and FP seems like a server side meltdown, ATM.I think there's a server side issue for departure times. I'm still on 4.10 and can't set them either
Disabled auto updates this morning for the same reason, has not stopped the madness. Plugged in at a commercial Chargepoint this afternoon. FP told me I have been charging at home for 98 hours. Cue the Twilight Zone music.This is why I have FordPass set to manual update only. I won't go to the next version until an update is good. Had enough of this.
Yeah charging screens are all messed up, I seriously wonder if anyone tests these before they go out, this is wild.Still on 4.10 also and FP seems like a server side meltdown, ATM.
Iām not far behind. Preconditioning never works now, FordPass no longer knows when the car is plugged in, nor does it report when the target charge has been reached, it still shows 3 messages that were deleted several days ago, just now reported the 2.4.1 update which actually happens about 36 hours ago, and still wonāt let my schedule securilert. The last one being an issue since that feature was introduced. Thereās probably more, but those will do.I suspect my FordPass updated and now it is unusable. All I get when trying to edit anything is the loading screen. Reminds me of the original version of FP....
Without reading all 7 pages.....is there any way to fix this or do I just have to wait for the next update and hope it works better?
It had been this way since the 18th?
I'm having this same issue. On the charge logs I also don't see any logs since the app update happened. I was not having any of these issues pre the update, so this is all new for me. Charge reporting was accurate till now. Job 2 car, running android 12 on pixel 6 proOk new weirdness for me. Iāve put my car in charge three separate times in the last 24ish hours. Every time the charging itself works fine. But the FordPass app is now combining them all into one and when I click the details for the charging session while itās on charge it tells me Iāve been charging for like 28 hours straight. Which I havenāt.
I also have the stuck notification badge. And now I cannot use FP to set up or modify a planned departure time for preconditioning. The spinner goes for a couple minutes and comes back that it was not able to work. Going into the MME to set this stuff up is a pain!!Anyone finding this release really buggy? FordPass was working fine for me until now. Now it wouldnāt remote start today at the end of work. And then when I got home, FordPass is telling me the car is remote started and I can extend it. But I go out to the car and itās not stared. Itās all a confusing mess right now
edit: yup and now none of my remote features are working. Even after uninstalling the app and reinstalling it. And itās showing my battery status from this morning instead of the current status. And it doesnāt recognize that itās on charge. Feeling pretty cranky right now.
Mine pretends to stop at my target (90%) and then keeps going to 100%. Last night it did stop at 90%, then at 5AM (not close to any departure time) it decided why not fill to 100% again. Can't save any changes in the app, can't delete and re-add any locations either.I came here to see if anyone had the same issue. Thanks for the report. Fingers crossed the car stops charging at target (85% for me) and not 100% like the app indicates.
Did you try in the Sync Charge menu in the car? You should be able to set everything in the car instead of in FordPass.For me, I can no longer delete / or modify the Charge settings location
I lost my house.
All I see is the dealership from last week (recall on the glass)
As i cannot modify them, the car charges to 100 % ever time i plug in.
Why does it not see where it is currenlty plugged in (my house).
I uninstalled the app. I cannot see charge details on ford.com either. Which had 2 entries for the same car. I deleted one of them.
