For those new to BEVs, here's a useful resource from Ford.
Unfortunate they use 80% instead of 90%.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
From the PDF:
Because a DC Fast-Charging Station can charge an all-electric vehicle so quickly, it’s a commonly used method for charging on long trips. What many owners don’t realize is that the vehicle automatically slows the rate of charging once the battery capacity is above 80% to minimize stress on battery components. Since the cost of DC Fast-Charging is often time-based, paying for that last 20% can get very expensive.
Yes, even with the charging curve update it's slower from 80 to 90% than it is before it hits 80%, but 42 kW charging at an EA charger is still better than having to make another stop. And going from 80 to 90% at each stop will eventually prevent another stop or two on a trip.
ZuleMME
Zule
Denver, CO
21' Job1 P4X MME, 22' MYP
Implementation Engineer
Wow, this is a big line here:
"On an all-electric vehicle, if the minimum charge level dips below 15%, the vehicle will discontinue charging the 12V battery in order to conserve energy for the thermal management system. "
Parking at under 15% with any drain on the 12v is not a good idea...
RockwallRick
Lake Wales, Florida
22 Ford Maverick FX4
I’ve only done one road trip so far but it would have been nice to get up to at least 85% without having to wait for an hour! This is from my personal experience at the EA station in Lake City, FL. At the time I did not trust the EA station in Gainesville which would have been my preferred charging stop!
azuano3654
Jason
Utah
2021 Bronco, MME
So as a new MME Owner in a currently cold weather climate, looks like I'm better off leaving the charge limit at 90% if I don't need the extra 10% of range for daily driving even though temps are consistently <40 degrees. Seems like that's the way to go unless I'm going on a longer drive that will require the extra range.
Logal727
C
Of course the only EA station that’s at a Target and not a Walmart doesn’t work, still seeing 3 out of 4 down on Plugshare.
Cold or hot, you should charge at home to 90% unless you're leaving for a trip the next day.
JamieGeek
In the summer months you can keep the charge at 90% but don't necessarily have to plug in daily as that 90% will take you a lot longer (for my CA Rt1 90% will last me all week: I usually plug in Sunday and Thursday nights--Thursday's so its ready to go for the weekend).
