ForScan or Hardware for sequential LED headlights
CommittotheIndian
Travis
Indiana
2022 Ford Mach-E Select eAWD Star White
Indiana Supreme Court - IT
I'm wondering if adding the sequential turn headlights is simply a ForScan mod or a hardware swap between Premium and Select trims.
I get the Premium is a LED Projector vs the Select LED Reflector but are they really that much different?
I just did my first mod with ForScan (hands free liftgate) so I'm diving down the rabbit hole and wondering what else I could look at. Just no idea where to start.
CommittotheIndian
CommittotheIndian
Travis
Indiana
Just a bump to see if anyone has an answer.
breeves002
St. Louis, MO
2021 Mach-E GT PE
The headlights are completely different. Most likely the base headlights do not have individually addressable LEDs to save money. There is a headlight control module too. A swap may be more than just swapping the headlights themselves. I've seen this on many Fords in the past.
Bratapfl
Germany
MME AWD ER (Premium) built in April 2022
I'm wondering if anyone here succeeded in retrofitting the Premium LEDs into a select Model?
Devbloggs
Alberta
2022 Mustang Mach-e Premium AWD extended
Mechanic
I know other then the obvious differences, IIHS rated the headlights on the Premium and Gt as Good, versus the others as Marginal. Quite the drop in rating
