Forscan question
MajsterkoV
MajsterkoV
Bartek
Poland
MME 21 Premium Iced Blue , MME 23 select Vapor Blue Me , Explorer ST 25
TCU Cost on Polish Allegro about 550 eur . I have bought right lamp in Lithuania on Ovoko for 340eur, Also i have tried updating mache with VCM 2 copy from china manage to start dowloading updates aand then Ford VDRS stoped responding and i did that 3 times
rugedraw
Javier
Miami, FL
Auto Sales
Quit now before you mess something up. You should not be using anything cheaper than a Mongoose cable. If you continue to try to update the modules with that Chinese cable, you will brick something.
MajsterkoV
MajsterkoV
Bartek
Poland
Its not cable fault but poor ford accesability in Europe most of thimes when i try to do something it doesnt want to connect to ford servers
rugedraw
Javier
Miami, FL
Auto Sales
I agree that FDRS does not work well outside the US. It doesn't work well inside the US sometimes, too. However, I am not going to try to convince you or anyone to not use those cheap cables. Do whatever you want, just remember that you were warned.
  • Like
Reactions: GDN
MajsterkoV
MajsterkoV
Bartek
Poland
Cheap chineese cabel cost me like 100 usd max withs i 4 times more that for me so its better option that spending 1/20 what i paid for mach e on cable from usa
MajsterkoV
MajsterkoV
Bartek
Poland
I will also try VXDIAG NANO
EgiszZ
Egidijus
Europe
Ford Mustang Mach E 2022 Premium AWD
Could you write me what to change to have road sign recognition and speedometer in kmh I have allready got a ticket first time driving on street :cwl: 50mph in 50kmh zone sooo...
Try these:
0720-03-01Fxxxxxxxxx--
Speedometer Cal (SC) - Europe
0720-03-01x1xxxxxxxx--
• Intelligent Speed Assistance (ISA) - Enabled
0720-03-02xx8xxx--
8 = TSR enabled • TS disabled • TBS disabled • TSP disabled
Country code - not sure if this is needed.
0720-04-02****xx--Language Country Code (LCC) - 4C48 (LT)
0720-07-01xxxxx3xxxx--
3 = Nav Speed Sign (NSS) - ROW
706-01-01xx3xxxxxxx--
Show sign to not overtake:
706-04-0105xxxxxxxx--
05 = MCDS Right Hand Traffic • U Unused • MCR Eu • MCSLSU KPH
706-04-01xxx1xxxxxx--
1 = MCC Europe
EgiszZ
Egidijus
Europe
I managed to turn back kmh speedometer while APIM country code set to Lithuania (or PL).
To do so, you need to temporary change back to US code 5553, then set in APIM screen, Vehicle settings change turn option "show speed in kmh" ON. Now you can change APIM country code back to whatever you want. IPC remain with big kmh / small mph :)
I also noticed that if later you make any change to IPC as built, then it will mess up again and you have to repeat procedure to get back kmh to you dash.
This is only workaround I found working by now. If someone kows better, let us know .
Chapron
Detlef
germany
Mach e RWD EX TP2 / 2023.75
SAP Engineer
Is ist possible to have US UI and US English language in a german mach e? I can Switch to UK English but it does not sound like US. 🙃
MajsterkoV
MajsterkoV
Bartek
Poland
Pretty sure u can, but i think only if u change country code to us
Chapron
Detlef
germany
SAP Engineer
I am not sure if it needs to download US content out of the cloud as it is not part of the Language pack in germany.
Chapron
Detlef
germany
SAP Engineer
Another question: when I use the precondition funktion with a timer or remote via the app the front and rear lights get acticated as well. That does not makes sense and only draws attention to the car when activated while the car ist parked on the street. Can this be changes so the the lights do not get turned on?
MajsterkoV
MajsterkoV
Bartek
Poland
I dont know u should check forscan worksheet or ask on main forscan topic
