Front air vents not working?
Wolfpackmache
Drew
Mache
Took delivery of my silver MachE premium today and on the way home I decided to crank up the fan because it was getting hot. Come to find out even at full blast the chest level vents up front barely push out air. All goes out back middle. Floor and defrost are fine. Almost like there's a blocker in there from shipping I need to remove.
Did you have HVAC in Auto mode? Go to the climate screen and manually select the dash vents to see if that changes things.
Xlch59
Kevin
California Bay Area
2003 mach 2004 Cobra 2007 GT500
I probably drove the car the first hundred miles thinking it doesn't cool very well. Then figure out all the vents where closed...duhh.
Always good to read the manual and understand how Auto works, as well as how to manually direct all airflow to the vents and verify they are open.
In addition to the manual stored in the vehicle's screen, you can download searchable PDFs to your phones, tablets, and computers at owner.ford.com.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
I’m going to go with “the vents are closed.” It’s been one of the more common questions around here. Because the indicators/actuators are tucked behind the big screen they’re easy to miss.
