- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
That would seem to suggest that the problem was caused by a dirty windshield. Periodic removal of the camera and cleaning of the inside of the windshield with a jumbo Q-tip may be required? Realignment afterwards may be required as well.I might've found the problem. The vehicle had the windshield replaced under another recall 21C22 back in February so I decided to remove the rain sensor cover above the rear view mirror, disconnect, remove And clean the rain sensor and IPMA camera very carefully, clean that small area of glass with a q-tip and a little air reinstall and reconnect the sensors very carefully. I cleared the codes then took it on a few road tests in the morning and the afternoon for a few days. Everything functioned correctly and no more messages came up on the IPC. I have been monitoring the status for a week now and everything is still good to go. I will be continuing to monitor for a month until I'm satisfied this was the issue and it has been resolved. I sent this information to Ford as well and hope this will fix most of these vehicles that are having the same problem.
