Frunk stuck - help!
Lynsey
San Diego, CA
2022 Mustang Mach E GT - Star White
You have free roadside assist...you could try them and see if they can help?
AKgrampy
Fairbanks, Alaska
Is there anything in your frunk that may have jammed the mechanism?
Shayne
Northern Ontario Canada
2021 MME4x Prem
Where would you recommend placing the screwdriver? Unfortunately the mechanical release is disengaged with the electrical one over-riding it. I can still attempt to hit the electrical release but it just spins without opening it further. We've tried placing a lot of pressure, a little pressure, side pressure, etc. onto the hood while simultaneously pressing the electrical release button on the app.
Are you suggesting that I try to place something on or near the latch itself while pressing the electrical release?
as huntingpudel noted in the old ones if it pushes down a bit to clear the hook of the latch the screwdriver slips between the hood and the grill where the latch is and the latch moves sideways.
When I noted in the past by no means did I mean on this vehicle. Old rusty ones that needed grease. Really not sure how all the electronics works on this one. Screwdriver and push the latch sideways until the hood releases. Pushing down a bit so the hook clears the hood rod. Not too rough do not bugger it up it is under warranty.
The cable is probably broken so you won't be able to get it open yourself. It's happened to someone else with a brand new delivery. The cable was either installed improperly at the factory or broke. Here's what the dealer had to do:
VERIFIED CONCERN. FOUND HOOD / FRUNK RELEASE INOP. REMOVE KICK PANEL TRIM AND FOUND CABLE DAMAGED / BROKEN. REPLACEMENT OF CABLE IS REQUIRED. REMOVE UNDER BODY COVER AND PARTIALLY REMOVE FRONT BUMPER COVER TO ACCESS AND RELEASE THE HOOD LATCH. REMOVE ALL FRUNK INTERIOR PANELS AND FRUNK STORAGE COMPARTMENT TO ACCESS AND REMOVE COWL AND CABLE. REPLACE CABLE AND RE-INSTALL COWL, WIPERS, AND FRUNK PANELS. CONCERN IS NO LONGER PRESENT. REPAIR VERIFIED. M-TIME REQUIRED TO ACCESS AND RELEASE THE HOOD LATCH.
2022mache
Ames, IA
2022 Mach-E
Update! After spending hours trying to open/close this stupid frunk today, we finally got it open! One person pulled up really aggressively on the hood, and the other took their finger and messed with the latch mechanism. I think it is very likely that the cable is broken and/or there is an electronic glitch from trying to open it on the app on my phone.
Needless to say, I will probably never attempt to open that dumb frunk again. I am hopeful that the dealership will come up with a solution to fix the problem long-term.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Retired Engineer
Glad to hear you got it open! But of course sorry to hear it was such a headache. I use my frunk often and really like it, so I hope once it’s fixed you’ll want to use yours. (Getting an F150 Lightning key fob with frunk button makes it all the better. There’s a thread on that.)
If it’s any consolation, my car has to be towed into the dealership two days after I took delivery of it. Luckily it was only software that needed updating, and it has been largely trouble free since.
Best of luck!
Ford Motor Company
Official Ford Account
This morning I attempted to unlock the frunk through the phone on my app. It is now stuck partially open. It seems that the first unlatch took, but the second will not unlatch completely. It will not open or close from here. The manual release in the car does not do anything. We have tried multiple ways to push it back closed. We have tried to release it open while pulling up, pulling the manual, pressing the button the app, etc. We have also tried maneuvering a device to try and press the emergency frunk release inside of the frunk. Nothing is working. I can't drive it locked partially open. Help!! What have people done to solve this issue? I have searched the forums and it seems that ultimately some people have had to resort to take it into service and get the latch replaced. Ugh, so frustrating! Especially since I just got my vehicle 2 days ago, and can't drive it now.
Electrifiedsince2013
Kristin
2022 Mustang MachE, 2020 Mustang Convertible
health care
Try it from the keypad? Punch in your number and then 7-8 immediately after and hold it. Probably won't work, but worth a shot.
What does the 7-8 do?
Kristin
health care
Nice that Ford Motor Company monitors this and responds. This is the second post I’ve seen today with a response from Ford, I like it ?
It opens the frunk when pressed right after entering your keycode.
If the frunk doesn't open from the screen, PAAK, or manual release lever, the door code isn't going to do it. There is a mechanical issue with the latch release. OP probably will not be able to open their frunk ever again unless they have the dealer take it apart from underneath and replace the broken parts. If their 12V battery dies they will be screwed since the emergency release won't work either.
Kristin
health care
Thanks. I’m learning all kinds of new stuff tonight.
