Frunk
Caliroute1
Scott
Wesley Chapel,FL
2021 Mach E GT
Operations Manager
I am in need of assistance I saw a post on the forum about opening the frunk on the door keypad by pressing 8 That works great but now when I use the keypad the frunk opens when I don’t want it to Also Is there a button for the trunk? I watched a video and said to push 5/6 That didn’t work Yes my code has a 8 in it Do I need to change my code again?
JohnnyForensic
VA, US
Digital Forensics
It sounds like you might be using the keypad when the fob or a connected PAAK phone is within range? If so, it’s overriding the need for you to enter the access code and taking the button press as the command to open the frunk. Best guess. Try this with the MME out of range of a PAAK phone or fob.
Bonehead
Malibu
'25 MME GT Performance ('21 MME Premium AWD Ex)
Hmmmm.... I tried pressing 8 - nothing happens.
If all you pressed was the 7-8 button it won’t open. You need to enter your door unlock code then press the 7-8 button. ??
Correct. If electronic frunk popping isn't enabled in the vehicle, this won't change that.
Well, it allows job 1 owners to do something. And blame it on PAAK. That’s a bonus . Of sorts. ;)
Bonehead
Malibu
Yes, I was doing that. I just now discovered that my personal door keypad code was wiped out for some reason. I had to dig up the original factory code in order to reset it.
The "personal code" + 8 is now working to open the frunk.
And I'm now storing the original factory code on my phone in case it gets wiped out again...
Caliroute1
Caliroute1
Scott
Wesley Chapel,FL
2021 Mach E GT
Operations Manager
Well it works great for me. Only problem now is whenever I enter my code it unlocks and the frunk opens. I did it with out the key and my PAAK. STILL opens the frunk. I might have to change my code. But is there another number to open the trunk?
Caliroute1
Caliroute1
Scott
Wesley Chapel,FL
2021 Mach E GT
Operations Manager
No dice. Uggg
