timbop
- Tim
- Jan 3, 2020
- New Jersey
- Solar powered 2021 MME ER RWD (CA RT1)
- Software Engineer
When driving what mi/kwh are you getting? If that hasn't changed then there is no "real" problem. I suspect the reason it seems to charge slower is that you are looking at the "miles added" instead of the percentage. Look at the percentage added over time as your guide to whether it is charging slower. Better yet multiply that by 88 to know how many kwh you are ACTUALLY getting over a period of time.Have you figured anything out on this? I am having the EXACT same issues, minus having the Paak update. My ER AWD suddenly lost about 100 miles on the GOM, with no changes to environmental or driving characteristics. Charging has slowed considerably. I understand that it's called a GOM for a reason, but 100 mile range loss on the meter, out of nowhere, seems to point to a problem. Best GOM I get now is about 230.
The GOM and charging in the app appear to use the same deeply flawed algorithm to compute range/efficiency. Do yourself a favor and treat what the GOM says with the same level of trust you give a politician running for reelection.
