Handles!!
Depends on how strong the actuators are for the "presentation" phase; remember push button and door pops out. Are they strong enough to break through a frozen car?
Once popped out you don't have to use the handle, you can slide your fingers behind the door and pull (and it wont close on you because the "presenter" is holding it open).
Note that MI also has freezing weather; Canada doesn't have a corner on the market.
From what I’ve heard the actuators are quite strong. We’ll be grabbing the door edge in snow/freezing rain. I definitely expect the trough to fill with ice in a wintry mix. It’s better than having flush handles freeze shut!
That is a real question. I hate reaching into anything that will snap a nail off. My manicures are not free.
You don’t have to use the handles at all. When you push the button the actuator pops the door out several inches. If you don’t want to use the handle, just grab the door edge. That’s the way you open the back doors-no handles back there.
DaveQ
Fernandina Beach, FL
Mach-E4X, HR-V, Insight, Maserati Levante S
Someone please tell me the door handles are slanted enough to not hold water. I can already tell that I will be cleaning this dirt catcher daily.
makooy
Rotterdam, NL
Mach-E RWD SR Lucid Red TP+
IT Consultant
As far that i've seen yesterday it is a dirt catcher. mostly dust and stains from rain.
Will check saturday if it's steep so water flows out of it.
Cnote
Texas
2014 Corvette Stingray, 2021 Mach E premium SR RWD
On the car we had on display here the open hook of the first picture was ok, the 2nd picture handle looks very uncomfortable...
[/QUOTE
I suspect 90% of the time we're just gonna be grabbing the edge of the door anyway, rather than the handle. Think about what you do now when the door is already part way open... Do you tend grab the handle to open it the rest of the way, or just the door edge? I think I usually grab the door edge.
I already have to grab the door edge for one of my current vehicles so this will be second nature for me.
ArtyMachy
Arthur
Canada
Mach E 2021 Select AWD
Do you think it would be an easy mod to just remove the handle without leaving a trace ? I would prefer to just grab door edge all the time and get rid of the ugly handle.
DaveQ
FE owners, please write up some good procedures to remove the handles for the rest of us to follow (only the successful ones) ;)
dbsb3233
TimCO
Colorado, USA
I'm guessing there's screw heads on the inside of the door holding it on.
Cnote
Texas
I'd assume it's on there using a bolt or screw or something, so not sure if it's easy to remove. I think I'll be able to ignore the handle since it's small and essentially blends in with the door frame if you don't look to closely ?
Removing it will probably leave holes to fill and repaint.
DaveQ
Wonder if we can not have them installed as an option (credit). They each must be worth a couple of hundred dollars, right? ;)
dbsb3233
TimCO
Colorado, USA
Wonder if we can not have them installed as an option (credit). They each must be work a couple of hundred dollars, right? ;)
Only when built by the government. ☺
